WANTED: good working air/smog pump
Old Nov 9, 2022 | 06:53 AM
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
Looking for a good working original or reman smog/air pump for my 83 LU5 T/A. It can come from any LG4, LU5, or L69 car, and Im 99% sure an LB9, L98, or L03 pump would work. I don’t have to go through emissions here in AZ, but I absolutely can’t stand when factory installed equipment is not in place. I’m not worried about the cosmetic appearance of it as it will be properly refinished, just as long as it works and has no bearing noise. I’m in PHX. Let me know what ya have! Thanks 👍
Old Nov 9, 2022 | 10:50 AM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Re: WANTED: good working air/smog pump
i definitely have one text me my number is (612) 860-2513
Old Nov 9, 2022 | 11:10 AM
1983LU5TA's Avatar
Engine: LU5, LSx
Will do! Thanks
Old Nov 10, 2022 | 09:29 PM
NoEmissions84TA's Avatar
You could remove the guts from yours and give it new bearings.
It wouldn't pump any air, but would look the part.
Old Nov 10, 2022 | 09:33 PM
1983LU5TA's Avatar
Engine: LU5, LSx
I know about gutting it, but that is absolutely not an option. It must function properly to keep the cat happy.
Old Nov 12, 2022 | 08:01 PM
Not necessarily true.
Remember that the cats that were originally installed from the factory were 3-way plus air.
From Walker: This system was not very efficient and was phased out in the early '80s, when the current three-way converter was introduced.
I assume that you are still using a stock cat?
Old Nov 12, 2022 | 08:05 PM
1983LU5TA's Avatar
Engine: LU5, LSx
Im aware of how a 3-way cat works. I’m running L98 TES and a full 3” exhaust with an aftermarket cat with AIR tube. Point being, I want everything to function as designed. There is no reason to gut an air pump, or eliminate any emissions equipment. It’s only a 14.30 LU5 car. Nothing is to be gained by hacking it.
Old Jan 29, 2023 | 02:14 AM
jbrooks6104's Avatar
Car: 1987 Iroc-z
Engine: V8 305 TPI
Idk if you're still looking but I have an original and working air pump out of a 87 Iroc-Z.
Old Feb 2, 2023 | 01:35 PM
smoke29's Avatar
Car: Anything that handles
Engine: 383
Axle/Gears: 3.25
I also have a original working air pump from a 87 TA along with a bunch of TPI parts.
Also, a good set of 198 heads for free, you pay shipping.
Old Feb 2, 2023 | 03:30 PM
MLF's Avatar
MLF
Car: 1983 firebird TransAm
Engine: 5.0 L CFI
Hello,
I do have some parts that are original and functional if you are still looking.
Melissa
Old Feb 14, 2023 | 12:16 AM
1983LU5TA's Avatar
Engine: LU5, LSx
Found what I needed locally. Thanks chaps.
thtanner
Aug 13, 2019 05:56 PM
TRAXION
61
Apr 29, 2012 06:47 PM
dennine3003
Nov 18, 2005 07:23 AM
Dan88IrocZ
Jun 1, 2003 03:53 PM
KiLLJ0Y
Jun 23, 2002 11:22 PM
