WANTED: Brass Heater Core
Car: ‘87 Base Firebird
Engine: 2.8 V6
I’m looking for a brass replacement heater core to replace the one that just died on my 1987 Firebird. I understand that OEM/NOS heater cores are $$$, I’m fine with a used one as long as it’s brass and isn’t leaking. Bonus points if you’re willing to cut a deal to a broke college student.
Looking for shipped to or pick up within 75 miles of 24141, Virginia.
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: WANTED: Brass Heater Core
Don't believe the repeated old wives tales of aluminum cores.........if that's what you're worried about.
Engine: 2.8 V6
Engine: 2.8 V6
Well, my wifes 2005 F150 is almost 20 years old with around 230000 miles on it and the factory original aluminum heater core is still working. Ages ago I had a 1986 grand am, it was about 10 years old and had 100000 miles on it when the heater core started to leak. When I got it pulled out......it had an aluminum core with molded plastic tanks........one of the plastic pipe fittings has split.......core was fine. Not to mention that aluminum cores disperse heat BETTER than copper/brass.......the heater will actually start transferring heat quicker. I see no reason to worry about aluminum, just make sure the overall build quality looks good.
Car: 1984 Trans AM
Transmission: 700-4r
Every 3 years or so, flush your cooling system with the heater controls set to heat. Be sure to use ONLY distilled water mixed 50/50 with your anti-freeze. Been doing that for 20 years with no problems nor corrosion.
Nothing wrong with aluminum heater core or radiators following my suggestion.
Engine: 2.8 V6
. Most were factory original and very tired. Thread
