LT1 A/C Delete Pulley and 1LE Duct Pictures
Old Apr 21, 2002 | 03:39 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are a couple of pics of the new parts for my LT1 motor.
This is the A/C Delete Pulley so that you can run the serpentine belt with the A/C removed,
Part number is 10115875 and the my price is $41.04, list is $54.72
This is the 1LE Air Duct,
Part number is 25147187 and my price is $53.54, list is $71.38.
The fitting for the silencer tube is sealed. I am going to cut off that fitting so that it is flush.
Old Apr 21, 2002 | 01:13 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
hmm, i thought that the 1LE elbows didn't have a silencer
BTW does your A/C delete pulley fit your accessory bracket nicely?
I had to grind off a small amount in order to get mine to fit.
Old Apr 21, 2002 | 04:45 PM
Zepher's Avatar
The 1LE doesn't have a silencer, I think the mold is the same for the 1LE and the non-1LE, they just cutout the hole for the silencer tube.
If you look into the that silencer tube fitting you'll see the it doesn't go into the duct.
My A/C Delete pulley also seems like it needs a little grinding.
One of the bolt holes doens't line up perfectly, the bracket needs to come up about an 1/8", it hits the bottom of the PS Pump.
Old Apr 21, 2002 | 04:54 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
That's weird, my AC delete pulley fit onto the LT1 bracket perfect....maybe because I was using an F-body accessory bracket and you're using one out of a Caprice?
Old Apr 21, 2002 | 06:40 PM
Zepher's Avatar
That could be a possibility.
I am considering getting an LT4 hotcam kit and slapping that in since the motor is out of the car.
I am also going to change the front and rear seals as well as the oil pan gasket so that I know that they won't leak any time soon.
any other recommendations to do to the motor before I drop it in?
Old Apr 21, 2002 | 07:03 PM
Drastius's Avatar
Engine: Caprice LT1
Do you have emissions tests to pass?
I put on a set of headers and removed the EGR system.
Old Apr 21, 2002 | 08:13 PM
Zepher's Avatar
They only do visuals here for emmisions, but I know where to go.
Old Apr 21, 2002 | 08:19 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Make sure to get the proper springs for the hot cam. Also it'd be a good idea to go to 1.6 rockers with the cam.
Old Apr 21, 2002 | 10:03 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Take the oil pan off and check the pan gasket for condition before buying a new one. They are reusable.
I would highly reccomend the hot cam. I like mine alot.
Kory
Old Apr 22, 2002 | 04:32 AM
Zepher's Avatar
I am getting the Hotcam kit minus the 1.6rr. Going to trade my SLP Dual CAI for it.
I was hoping to use my SLP CAI with my LT1, but it might not fit, so I guess I should trade for the cam and install it while the motor is out.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
chubsworth
Aug 26, 2015 02:34 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
