Worth it to build a 2 bolt 350?
Old May 6, 2002 | 09:01 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I can get a 1 piece seal 2 bolt 350 bare block for $150. The block is in good condition but needs bored as expected. I am not going to use spray and I don't expect crazy power, but I would like to make enough power to beat stock LT1s. So would it be worth it to build it?
Old May 6, 2002 | 09:21 PM
sIcK pUpPy's Avatar
These blocks will handle quite a bit. 4 bolts aren't really nesessary unless you're spinning ti to the moon. You can safely run NOS, forced induction, or whatever tickles your fancy, just as long as you carefully plan out your rotating assy.
LAtes,
JD
Old May 6, 2002 | 09:27 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Absolutely!!!!
Build it. A 4 bolt is actually very over rated. The best thing they're for is trucks. Due to the pulling that most people do with trucks, it puts a lot of strain on the crankshaft.
A 2 bolt can easily handle ~400HP. And are also good to 6000RPM.
Now if you were going to use a blower or spray, then I would upgrade it by using splayed caps. If you don't know what those are, here's a crappy pic.
Regular 4 bolt ---- !! !! ---- The bolts all go straight in.
Splayed 4 bolt --- /! !\ --- The outter bolts go down into the block at an angle. This distributes the load more evenly on the block, and in turn puts less stress on the bolts.
But that's not needed if you stay ~400HP or less. If you want just a little more piece of mind, then use ARP cap bolts. They have the highest tensil strength as well as the most uniform design and manufacturing than any other company that I know of.
AJ
Old May 7, 2002 | 02:22 PM
TBurke's Avatar
Good to brag about but not necessary.
Old May 7, 2002 | 07:34 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I know lots of people running around with 2-bolts on insanely powerful engines. Some guy around here is running low 11's N/A on an uncapped 2-bolt in his Nova. You could easily get away with 400HP especially if its just a street car that doesn't see over 3500rpm much.
Old May 8, 2002 | 07:14 PM
360Iroc's Avatar
Two Words
Build It
Old May 10, 2002 | 09:48 PM
Hulk0202's Avatar
Have you ever heard anyone say "Damn, if I was a 4-bolt it would have survived!"? I haven't.
Old May 16, 2002 | 01:27 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I have never ever seen a crank fall out on the ground.
4 bolt blocks and steel cranks are not nessessary for a good street motor.
Put the money into good cylinder heads, cam and quality machine work.
Old May 17, 2002 | 10:03 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have seen a crank fall out on the ground (Famoso Raceway, Bakersfield), but not on a street car and it wasn't because it didn't have four bolt mains. (it was actually a Hemi w/6 bolt caps)
-Nothing wrong with a two bolt 350 block-
If you're not running a 200 hp nitrous shot or a blower, it'll be fine.
Run it.
-Rich-
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
355tpipickup
Aug 13, 2015 07:35 AM
