Ok one of my friends had a house that burned down, and beside it sat a boat with a 350 in it, needless to say the boat got it... well he gave me the boat because i wanted to check out the motor, he bought it before last summer and the engine is new..... everything on the exterior of the engine is gone.....but the block assembly and everything is fine, it turns over and all,,, ok i have a 1989 rs 305 tbi 700r4, i wanna swap, what do i need... what off my car will work with the 350... what will i need to get .... everything, lemme knwo thanx
All exterior dimensions are the same. Starter, waterpump, alternator, pretty much anything you can see when you lift the hood.
T
T
If that's a "marine" 350 it should have some good HD parts in it,a 4 bolt block and maybe even a forged crank and pistons.Check it out,
One thing you have to watch out for is that MOST (not all) marine 350's were reverse rotation. Meaning that a 350 out of a car rotates clockwise if you stand in front of it looking at it while it's running. Marine motors spin counter-clockwise. That's because of the standard prop rotational direction.
Try and find that out first.
AJ
AJ
I'm about 99% positive that the only reverse rotation motors were only made in big block form and I don't think that those are even made anymore, I think the reverse rotation needed is acheived in the gear case now. But I took the motor out of my boat a couple months of and put it in my car. Your accessory brackets should all swap over, including your water pump and thermo housing. I would verify whether it is a one piece or two piece rear main. Mine is a 92 motor with a 2 piece rear main so I had to get a new flexplate.
Quote:
Originally posted by Tom91Bird
...... Mine is a 92 motor with a 2 piece rear main so I had to get a new flexplate.
You have a '92 block that has a 2pc. rear main seal? Is it a GM?Originally posted by Tom91Bird
And you may be correct about the gear box, but ANY Volvo marine engine that was a V8 was a SBC that was simply reverse rotation. But those were mass procuced. Most custom boats did/do have big blocks, and were just regular car/truck motors.
It still wouldn't hurt to check though.
AJ
Quote:
Is it a GM
Yes, it's a GM 350 crate motor.Is it a GM
