Motor and tranny in one piece?
Old May 21, 2002 | 03:17 PM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
Hello,
I was wondering if its possible to drop the motor and tranny into a thirdgen in one piece or if I will need to seperate the two?
SB
Old May 21, 2002 | 04:16 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Sure you can drop them in together...that's how I did mine. It made it a lot easier. Just make sure you have a friend with you to help guide the transmission in place.
Old May 21, 2002 | 04:27 PM
SilentBob's Avatar
Engine: 383
Excellent. Thanks for the response.
SB
Old May 23, 2002 | 09:57 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I pulled them out together and put them back in together.
Its actually alot easy to install the motor & tranny as a unit than doing them one at a time.
Old May 23, 2002 | 10:54 AM
SilentBob's Avatar
Engine: 383
Thats what I was hoping to hear. Did either of you do it with your manifolds or headers attached? I have SLP headers, but I have heard that they can have clearance issues with the brake lines and was curious if I should install them before or after installing the motor.
SB
Old May 23, 2002 | 11:31 AM
shiner16's Avatar
I tried to install my 355 and th350 in together with my Summit shortie headers bolted on, but there was no way that was going to happen. Ended up dropping the motor/trans in w/o the headers, then bolting them up later from underneath. good luck!
Old May 23, 2002 | 12:35 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I installed mine seperately, but mainly because I was doing it by myself and didn't want to destroy anything in the way.
I'd plan on putting the headers on after it's in.My SLP's were pretty tight, especially on the driver's side.Ended up jacking the motor up a little off the mounts to drop that one in, before bolting it up.
-Rich-
Old May 23, 2002 | 03:08 PM
SilentBob's Avatar
Engine: 383
Good advice guys, thanks. Ill leave the headers until the motor is in.
I cant wait to get a motor back in this SOB. Its only been out for about 2 years now.
SB
Old May 27, 2002 | 08:21 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I seen you boys with cameros doing swaps in one peice and I did my 86 bird in one peice but I ran into problems with the nose sticking out too far to get motor far enough back to slide over motor mounts, was it just a fake cherry picker (boom not long enough) or has this happened before? After the ordeal I went through I'll sell the car before I think about another engine swap.
Old May 28, 2002 | 10:21 AM
SilentBob's Avatar
Engine: 383
I ran into the problem with the nose, the short cherry picker and the motor mounts. I had to jack up the tailshaft on the tranny and that brought it closerm to lining up with the mounts. Then I set the engine down on the middle of the mount and moved the hook further up on the engine chain. Lifted again and moved it back some more.
Repeated this a time or two and finally got it in there. Thanks to all for the advice.
SB
Old May 28, 2002 | 05:30 PM
IHI's Avatar
IHI
We goofed by using one of those engine equilerizers so you could tilt the motor back & forth-that part worked great till it exploded (grandpa took hand crank off and welded double nut on so you could use an air impact to tilt it, weld broke) and dropped my motor/tranny about 3" luckily no damage-but we had the chains too short-so like you said we lowered it and lenghtened the chains to have some swing in it and that helped. I tell ya though, this motor swap was the most time consuming one I've ever attemped-alot of cussing and sweating. Just was'nt meant to be. (very long story) But like always it all worked out and I'm happy as hell so far.
Old May 29, 2002 | 11:24 AM
Morley's Avatar
SB
I put my engine in with the passenger side SLP header in place, but the driver side wouldn't go, had to remove the header.
~M~
Old May 30, 2002 | 11:42 AM
SilentBob's Avatar
Engine: 383
I had remembered when I pulled the motor I had to remove the manifold on the one side, but I wasnt sure about putting it back in that way.
SB
Old May 31, 2002 | 12:50 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
wrong post sorry
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
