can anyone help? need it fast
Old Jun 5, 2002 | 10:02 PM
Fade07W's Avatar
Okay everyone, I got the new motor in my car, see sig. I had an LG4 before. Now here is what I don't understand, I switched to a 350 mechanical fuel pump on the motor. However with the motor off and the key turned to the accesories the carb bowls were filled and i hear this whirring sound at the back of my car. Am I still pumping fuel? Or is this sounds okay? and if I am pumping fuel, is this sound okay?
Old Jun 6, 2002 | 07:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
'87 LG4's had both an electric pump in the tank and a mechanical pump on the engine. The intent was to reduce vapor lock.
You should be using a mechanical pump with three ports: inlet, output to the carb, and return. The return is important to avoid over-pressurizing the carb needle & seat valve.
Old Jun 6, 2002 | 10:15 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Check out your original post..I rounded up a bunch of help for ya...
https://www.thirdgen.org/techbb2/sho...478#post706478 and here..
https://www.thirdgen.org/techbb2/sho...hreadid=111680
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
