Well, my LT4 heads and Intake arrived. :)
Old Jun 11, 2002 | 09:29 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are a few pics,
Going to have the valve seals replaced before I install the heads.
Maybe even get some port work done, depending on price.
Old Jun 11, 2002 | 10:10 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
GIMME.
Lol, they look sharp, Zeph.
Old Jun 12, 2002 | 12:22 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
wow those look nice.
Those heads look like they really want a port job too me.
Old Jun 12, 2002 | 02:44 AM
Zepher's Avatar
Thanks,
I am going to take my time building this motor. I want it done right the first time, and since I am poor, I have no choice but to take my time.
I will find out tomorrow what it costs to get the heads done, hopefully it's not too much.
Old Jun 13, 2002 | 10:39 PM
89Irocz23's Avatar
lol you must of brightened up the picture cause the intake looks pink on my computer. Thats what my intake is gonna look just like after john is finished with it.
Old Jun 14, 2002 | 05:01 AM
Zepher's Avatar
Picture isn't brightened up, my Kodak DC-260 has a problem with bright red, makes it look pink.
Old Jun 16, 2002 | 10:52 AM
traumatech's Avatar
Hey zepher,
I just stumbled across your stuff here. I found the lt4 intake at SDPC and decided to do some research, and I'm wondering if you could help me out. My plan at the moment is a 383 with SS LTR's, SDPC intake base, vortec heads, and probably the Gen VII DFI. I know the numbers I can get from that, but now I'm curious, how would they compare to the same setup with an LT4 intake? And do you have to have lt4 heads to go with that intake or will it bolt to vortec heads? My end goal, which I could reach with the ltr setup is 300 rwhp, and at least knock on the door of 11's. I'm sure the little parts will add up quickly on either build up, but any idea as to whether the lt4 little parts are adding up quicker than the regular tpi? Thanks.
Old Jun 16, 2002 | 12:52 PM
Zepher's Avatar
I have no idea if the LT4 intake will bolt to anything but LT4 heads or aftermarket heads modified for the LT4 intake.
the best person to ask is John Millican since he has been working with the LT1 intake for the Gen 1 small block heads.
Old Jun 16, 2002 | 01:50 PM
89Irocz23's Avatar
Im in the process of a lt1 intake swap right now. I talked to john and did soem research. The lt4 intake will only work with lt4 heads or trick flow heads I believe. I guess the ports are different the done line up right on older heads.
Old Jun 20, 2002 | 12:36 AM
traumatech's Avatar
Where can I get the rest of the parts that I would need to put this together? I can't seem to find things like the fuel rails and some of the other little things. I'm sure I can use a lot of standard parts on the block, but what about sensors and fittings of the lt4 intake?
Old Jun 20, 2002 | 06:56 AM
Zepher's Avatar
I am using the Fuel Rails off of my LT1. I called yesterday for the price of the LT4 fuel rails and my cost is $271 per side (you need two sides for a complete rail) I figured $540 isn't worth the extra 3 grams/sec flow that the LT4 rail has.
Best bet is getting a complete used LT1 intake and buying the bare LT4 intake new and use the LT1 rail and TB. It's a little over $200 for a new LT4 intake. Complete LT4 heads run $1200/pair, my cost.
Old Jun 20, 2002 | 03:20 PM
traumatech's Avatar
That's what I needed to know. I wasn't for sure if the lt4 was just a worked over lt1, but I'm guessing part wise, that's what it is. I've read all the stuff about the real lt4 being redone from the block up, but I guess for my purposes I'll just take advantage of the intake mods. I'll probably start a new thread soon to try and dig out some more info/ideas for stroking an lt4.
Old Jun 20, 2002 | 04:17 PM
Zepher's Avatar
Re: Thanks
Actually, an LT4 is an LT1 with different Cam, Fuel Rails, Injectors, Heads, Valves, springs, rockers, Intake Manifold, timing chain set, and Knock Module. Everything else is the same.
Old Jun 22, 2002 | 06:08 AM
84LT-4's Avatar
Zepher your about 90% correct , except that corvette lt1 and lt4 engines have 4 bolt mains and a better nodular iron crank than the camaro or trans am lt1. so basically you have a lt1 w lt4 heads and intake which is the same combo im running. so if you want it to be like a production lt4 you need a lt4 longblock .also i read one of your posts when you first got your motor and you stated that you were going to clean it up and it would be in the car the next day being a little optimistic arent you?. ive had this combo running for 2 years and its not as easy as some people think good luck with your project and hope to see it running soon and maybe painted to. if you need any help with this swap e mail me and i will be glad to assist .
Old Jun 22, 2002 | 08:29 AM
Zepher's Avatar
Well, it's torn apart now, heads are in the shop. I should have the motor in the car in a month or two. Still need to find a tranny.
Going to the track to watch some imports, be back later.
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
