Place to buy reconditioned blocks ???
Old Jun 15, 2002 | 04:07 PM
92GTA's Avatar
Is there a place on-line whre you can buy fully reconditioned and ready to assemble short blocks? I want a 400 SBC 4-bolt, unbored or atleast nothing more than .30 over.
The reason I ask is because I don't want to screw around with looking for a block, having it checked and reconditioned. I just want it now
Alex
Old Jun 15, 2002 | 05:13 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Umm you dont want a 400 SBC 4 bolt.. They are actually weaker than a 2 bolt 400 SBC
Kat
Old Jun 15, 2002 | 05:53 PM
92GTA's Avatar
Are you sure? I was told by a local shop that they were better, see what you can learn on the internet
Well then in addition to my first question, can a 2 bolt be turned into a 4 bolt or will it take a 800 HP build as a 2 bolt?
Old Jun 15, 2002 | 10:28 PM
iroc22's Avatar
Can't you get one through Recon Engines? I don't know their website. Ask Snowdog 91 Formula, he got one from Recon I believe.
Old Jun 15, 2002 | 11:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
throw a 455 SD Pontiac in there
serioulsy though, i wouldnt go with a 400, they have known-cooling problems
Old Jun 16, 2002 | 12:57 AM
matchstick's Avatar
2 bolt 400's are reliable up to about 600 hp. They are stronger than 4 bolt's. For 800 hp, you need to have the main caps splayed. So long as you're cooling system is up to par, 400's don't have over heating problems either.
Old Jun 16, 2002 | 12:25 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
92,
I think PAW (Performance Automotive Warehouse) out in Chatsworth sells reconditioned standard bore blocks that have been resleeved.
I would probably go for a Dart or Motown block for the kind of engine you are planning. I'm not sure if the factory Gm block casting can take a 4 inch crank in it. It'll add some coin to your buildup, but strokers do cost money.
I love my $500 305 L69 longblock!
Old Jun 16, 2002 | 01:04 PM
92GTA's Avatar
Thanks, I was told that a 4 inch would fit, that's why I'm even doing this. Otherwise I'd just do a 383 or something.
www.ReconEngines.com
I'll look into the non GM blocks. thanks.
Old Jun 18, 2002 | 11:33 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
I had a magazine dating back to 1998 (Engine Masters) that detailed the buildup of a 427 small block, but I lost it. Damn!
It provided some useful information to show where the block needed to be clearanced to allow for a 4 inch crank. I do believe that the engine in that magazine did use a production bowtie 2-bolt block as the foundation.
Old Jun 19, 2002 | 01:03 AM
92GTA's Avatar
Sweet, but I can't believe you lost it That would have rocked!
Do they have a web site where you can like order past issues????
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
gixxer92
Sep 1, 2015 04:32 PM
