Offset Ground Cranks
Old Aug 10, 2002 | 09:35 AM
83 MidniteZ's Avatar
After reading this months HotRod Magazine I began talking with the other workers at my shop about building another engine. I want to use a 400 block and 350 crank. Weld the rod journals to retain the larger journal size and offset grind them 0.082 over stock and make a 386 with a 4.155 bore. It would also have a higher RPM capability then the common 383 without the fitment issues.
Has anyone built any engines using an offset ground crank?
Old Aug 11, 2002 | 08:42 AM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
that sounds like a lot of screwing around for 10 cubic inches. without the offest you have a 377, why bother with welding and grinding? not to mention you have to find a piston for that wierd stroke when there are pistons for 377's all over the place.
Old Aug 11, 2002 | 03:47 PM
Actually you can use stadard 5.7 inch rods and common aftermarket pistons with a compression ehight of 1.19 or use 6 inch rods and a piston with a compression hight of about 1.219
Seems like a simple alternative to a 383. without ruining the block for clearance of the 400 crank.
Old Aug 11, 2002 | 06:16 PM
Car: 1971 Corvette
Axle/Gears: 3.36
ruining the block?
so all the guys running 383's have ruined their blocks? i just finished putting a 383 short block together and i think the block is just fine. i still think offset grinding is a huge waste of time and money. just use the standard 350 crank.
why would you want less compression height with the shorter rods? even if that is a typo, the 5.7 rods with the taller of the 2 pistons is still shorter than the 6 inchers with the short pistons.
Old Aug 11, 2002 | 07:08 PM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
Offset ground cranks are very common in classes like stock eliminator.
Old Aug 12, 2002 | 04:52 PM
Well seeing how I work in a machine shop it wouldn't be any real time or money that I have to give up or sacrifice. Just trying to see everyones opinion on it. I figured the engine would really benifit from the extra stroke
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
billybob6110
Sep 23, 2015 01:30 PM
rb85TA
26
Sep 14, 2015 10:29 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 5, 2015 07:48 PM
