305 monte SS in to a 91 firebird..need help
Old Aug 12, 2002 | 09:30 PM
Guest
Guest
Posts: n/a
I just got a 1991 Firebird off E-bay and i have a monte Carlo SS 305HO and i did a .030 over bore on. the 91' Firebird has the 3.1L V-6 in it. how all will i need to get the 305 in the Firebird. i do not want the V-8 computer controled and i will be running a Holly 650CFM Carb. i know i need motor mounts but what about the bellhouseing on the Stock 700R-4 trans? will it bolt up or will i have to get a new bell houseing. Also does anyone new what rear end was put into the 91 Firebird with the 3.1L is it a 3.73 open diff? i need to get my parts list going so i can start saveing money. also what is the best shift kit out there? i heard bad things about the B&M shift kit. Let me know what you think! Thanks
Old Aug 12, 2002 | 09:32 PM
Guest
Guest
Posts: n/a
Also the 305 motor came out od a 1986 Monte SS. and one more thing. What kinda of headers should i use? i want to run 4" pipes to the Flowmaster muffler with 3.5" pipes out. let me know what you think!!!
Old Aug 12, 2002 | 11:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 305 is a small engine. You don't need big headers. 1 1/2" to 1 5/8" primary tubes is all you're going to need. 3" maximum exhaust pipes.
I don't even have that big of exhaust pipes on my race car. 3" in and out on some bullet mufflers.
There's nothing special about that 305. Why not just drop in a good 350?
Old Aug 13, 2002 | 06:13 AM
Guest
Guest
Posts: n/a
I Got the 305 For Free. and i have alread put alot of money into it. i'm thinking about just boreing it out again to a 350.
Old Aug 13, 2002 | 06:47 AM
JKmotoJoe22's Avatar
The rear end in that car is going to be something likle a 3.23, or a 2.73 one wheel wonder. As far as the motor, if your using a carb, you don't need to worry about the ECM. But you will probably have to use a new fuel pump. You might even think about new front springs. But like the other guy said- "why bother with a 305?" 350's are dime a dozen, and machine work isn't that expensive!
Old Aug 13, 2002 | 11:49 AM
iroc22's Avatar
You can't take 305 cylinder walls to 4" to make a 350.
Old Aug 13, 2002 | 03:23 PM
Guest
Guest
Posts: n/a
you can't? itsn't it the same block?
Old Aug 13, 2002 | 05:06 PM
iroc22's Avatar
Nope. Externally they look the same, but if you ever open up the 305, the cylinder walls aren't thick enough to go 0.624" over. Some 305 blocks (late 70s early 80's) can't even go .060" over.
Old Aug 13, 2002 | 07:13 PM
Guest
Guest
Posts: n/a
well do you know if the stock 700R-4 trans will bolt up to the 305? or do i need to get a new bell houseing?
Old Aug 13, 2002 | 08:08 PM
iroc22's Avatar
If it's originally a 3.1, then you need a V8 TH700-R4
Old Aug 14, 2002 | 12:33 AM
Guest
Guest
Posts: n/a
can i just swap out the bell houseing on it?
Old Aug 14, 2002 | 12:25 PM
iroc22's Avatar
No. It's a fixed case.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
