Stupid Question?
Old Aug 31, 2002 | 08:43 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Stupid Question?
Hello, i was wondering if i would need to put silicon on with the head gaskets? I took off the heads from my fastburn crate motor to put the hot cam in and now it is time to assemble everything! I was wondering if there is any difference between aluminum and cast iron heads? I got the stock replacement head gaskets. Thanks
Old Aug 31, 2002 | 11:09 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
99.9% of the time you don't put anything on the head gaskets.
AJ
Old Aug 31, 2002 | 12:25 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks AJ. I tried to call Scoggin-Dickey since that is where i got the motor from but they were closed and is is tough to call during the week with work. I'm still trying to get a definate answer though you are probally right! thanks
Old Aug 31, 2002 | 01:10 PM
ede's Avatar
ede
you need gaskets made for aluminum heads on a cast iron block because of the differant thermal rates of each. i use k&w copper spray sealer on head gaskets.
Old Aug 31, 2002 | 06:19 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Also dont forget to use some thread sealant on the head bolts too.
Kat
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
