TTA heads . . .
Old Sep 9, 2002 | 01:40 AM
RoadRacer's Avatar
TTA heads . . .
Anybody know where to find a pair of TTA heads?
I'd like to put a turbo 3.8 in my GTA, but from what I understand, The narrower TTA heads are required to clear the shock towers.
Any suggestions?
Old Sep 9, 2002 | 05:22 AM
ede's Avatar
ede
considering people put BBCs in thirdgen f bodys i doubt if you have any clearance issues in reguards to the heads of a v6.
Old Sep 9, 2002 | 10:51 AM
1987 GN's Avatar
I think the narrower TTA heads were used so that the A/C could be kept in the car as well. They are the same as the 3.0 FWD car heads from the same era. I am not sure what specific car though, maybe a buick century? You also have the option of swapping in a buick 3.8 turbo which others on this board have done I think. Good luck.
Old Sep 9, 2002 | 08:27 PM
iroc22's Avatar
The original TTA heads were from a 89 LeSabre.
Old Sep 10, 2002 | 12:51 PM
mat89RS's Avatar
I have 3.8 fwd heads from an 89 regal. 25k. complete with rockers, springs , valves, seals are good ...valve covers are in execellent shape.
Make me an offer, email me .
Old Nov 4, 2002 | 12:21 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I am interested in those heads. I really have no idea what they are worth. Could you maybe shoot me an e-mail. dcsfreeman@lycos.com
Old Nov 4, 2002 | 03:12 PM
Roc87's Avatar
Car: '01 Vette 'vert
Engine: Ls1
Transmission: 6sp
Be sure you are using a TTA block if planning on using the FWD heads. If you're using a GN block w/ TTA heads, you'll bump the compression higher, and not be able to boost as high. I'm using Complete '86 T-Type drivetrain and didn't have any fitment problems, (Besides no bolt in motor mounts). I don't have A/C either. Just a S-10 style A/C delete pulley. Good luck!
Old Nov 4, 2002 | 03:48 PM
mat89RS's Avatar
You got mail
Old Nov 10, 2002 | 10:18 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
yeah you'll have to ditch the AC to use the GN heads, which is no big deal, hell I have a TTA motor and still ditched the AC
I believe the actual TTA heads were from a LeSabre but you can use a few different heads, not sure exactly what ones though..
Old Nov 10, 2002 | 09:45 PM
iroc22's Avatar
Originally posted by fly89gta
I believe the actual TTA heads were from a LeSabre ..
They are.....^^^ read my post above.
Old Nov 10, 2002 | 10:01 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Didn't even see that
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
