2.5L "Iron Duke" 4-cylinder swap to V-8
Old Oct 16, 2002 | 10:28 PM
DLTrahan83's Avatar
Ok I just got a 1982 Firebird wit ha 2.5L 4-cylinder "Iron Duke". Well I go the car b/c being it had a 4-cyl. that it would probably be a lighter chassis. I wanna do a V-8 engine swap. Would it be the same kinda swap as a v-6 to v-8 swap? If anyone knows of anyone that has did this swap let me know. Would I need a bigger radiator, stiffer front shocks and springs, and would the V-8 exhaust system route the same in a 4-cyl. car? I think all i need to do is get engine mounts and a radiator shroud for a v-8 car. Any suggestions or know how accepted.
Old Oct 17, 2002 | 01:58 AM
Joshua Leslie's Avatar
you will need a new tranny. maybe a new driveshaft, if the tranny is longer than the 4banger.
The reason for this is the bellhousings are different.
You will need new mounts, new accesories and accsessorie brackets, probably a radiator cuz a 4banger produces a lot less heat than 350
you will need a new fuel pump
Old Oct 17, 2002 | 02:16 AM
DLTrahan83's Avatar
thanks dude for the help
Hey dude thanks for the advice. :hail:
Does anyone know if I still need a Cat. Converter even if I take out all of the smog and emission junk?
Old Oct 17, 2002 | 10:42 AM
88redthunder's Avatar
Car: 1988 Camaro SC
Engine: 305 TBI
If you don't have smog and emissions stuff then you don't need a cat; its part of emissions.
Old Oct 17, 2002 | 01:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 2.5L "Iron Duke" 4-cylinder swap to V-8
Don't know how to break this to you, but they were all the same. By the time you get the V8 in it, it will weigh the same as a factory V8 car (w/o the emissions parts you're leaving out).
You will need a full V8 exhaust (can get by w/o the cat, as stated), which will route basically the same as the 4-cyl exhaust did.
Old Oct 18, 2002 | 12:02 PM
PIMPINPHIL's Avatar
hey,
didnt know weather you have a motor yet or not,but i have 305 tpi motor,with all accesories,and i through in the radiator and mounts also,the motor would come complete with computer,and wires,complete from tpi to oil pan,i even could throw in a driveshaft,you would need a tranny however,let me know weather your interested or not,
phil
p.s. if you want all this stuff i just listed,im asking 700,the motor has 120000 miles on it,runs pretty good though,i also have a external fuel pump,i would sell for a additional 100 dollars,all this is plus shipping charges,thanks.
Old Oct 18, 2002 | 02:13 PM
DLTrahan83's Avatar
Nah Man. I already have a big HP motor that i'm building up. But thanks any way.
Old Oct 23, 2002 | 10:18 PM
84 Challenge's Avatar
Probably should go with a new suspension from a V-8 car. I doubt the 4-cyl parts could handle a V-8. Someone correct me if I'm wrong.
Old Oct 24, 2002 | 06:38 PM
MNformula350's Avatar
I am pretty sure i remember reading somewhere b4 that the 4 cyl cars bumper (behind the bumper covers) were aluminum to try to trim some weight.
I have been looking for a 4 cyl firebird to check and if so they are goin on the Formula.
Old Oct 25, 2002 | 02:53 AM
DLTrahan83's Avatar
I i haven't heard about that but I took my nose off to replace the radiator on it b/c of a crack and that thing behind the bumper was plastic just like the other f-bodies. If u want a 4-cylinder bird i'll sell you mine for cheap needs some TLC. I dunno a 4-cylinder Bird just baffles me. Why would GM do that to a Firebird? I bought it B/C it was cheap, unique, and needed TLC. I thought about leaving it a 4-cyl hoping it would be valueable down the road. Bu tI said heck I'll take that 4 banger out and make this car the muscle car its supposed to be.
InfinityShade
Feb 21, 2016 01:29 PM
sailtexas186548
Jan 19, 2016 12:21 PM
formula_novice
Sep 5, 2015 03:58 AM
InfinityShade
Aug 22, 2015 08:00 PM
