cannot clear the new motor
Old Nov 14, 2002 | 08:16 AM
  #51
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Again, if someone could anwser a question for me? Maybe you 383backinblack?
Any other brand headers that will fit square after market heads other than hooker super comp's?
Old Nov 14, 2002 | 08:57 AM
  #52
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Im sure you cand find a header to fit whatever you have from most if not all of the major brands......the shape of the tube in the flange is important, however, as long as the opening of the primary is slightly larger than the exhaust port (doesnt interfere or stick out into the opening, or cover any part of the port) you should be fine.
Old Nov 14, 2002 | 06:30 PM
  #53
GOFASTER's Avatar
Engine: 388 ci
Are you sure that I can use different style headers to heads? I mean, the headers I have now are headman with round or oval ports (openings) and the heads I have are squre?
What type and style (and how much did they cost) headers are you running and heads? Did your ports match up?
PS I am posting a new post on my dyno numbers I got today.
Look for it!
Old Nov 14, 2002 | 06:47 PM
  #54
Car: '91 Camaro RS
yep
as long as the tube on the header is big enough that it doesnt obstruct any of the port on the head than it wont be a problem....i have hooker supercomps with 1-3/4 primaries ceramic coated....they are a specific part number to fit on a small block in a 3rd gen car. they are pretty big so there isnt an interference problem.
if you wanna know for sure, bolt them up with a gasket (make sure the gasket is right for the head ports first, check with the manufacturer for the right gasket #) after you bolt up the header take it off and check the imprint on the gasket, that should tell you what you need to know :rockon:
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
NBrehm
Aug 5, 2015 07:57 PM
