Ok to lift old motor out by TPI?
Old Nov 3, 2002 | 10:46 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
The used and abused 350TPI is coming out soon and I was wondering if I could lift it out by using a nylon strap wrapped under the plenum? I do want to try to sell the TPI so I don't want to damage it. Will is handle the load? Any better way?
Old Nov 4, 2002 | 12:19 AM
PonchoDoc's Avatar
What do you have against using a chain?
I would not even consider lifting by the plenum with a strap but it could work if you really want to do it that way, but why?
If you have stock runners they are kinda of thin and there is a chance that they will tear apart but I would think they could handle the job with a little distortion but take off all the front accessories to lighten up the engine as much as possible and take it slow, and be prepared for the runners to tear apart and drop the motor.
Old Nov 4, 2002 | 01:04 AM
Speartech's Avatar
Yes, that'll work fine! We switched over to using seat belt straps a long time ago when working around aluminum engine parts. Got tired of the dents and scratches left by chains!
Take a look at: http://www.speartech.com/coproj-1991ls1.html
The first few pictures show the straps on the TPI unit as we pull the engine and trans from our 91 Z28 project car. We have picked up many engine/trans combinations this way and have never had a problem (or a scratch!!).
Good luck.
Old Nov 4, 2002 | 05:13 PM
I read your article a little while back and I didn't think much of it. Hell, I my put the TPI back on just to but the new motor back in, seems like it will work perfect.
Old Nov 13, 2002 | 04:43 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Plant Protection where around Valpo are you? If you want some help pullin that motor or with anything else send me a PM..
Old Nov 17, 2002 | 03:09 PM
MdFormula350's Avatar
thats one heck of a engine swap in that camaro from the link!
Old Nov 28, 2002 | 03:27 AM
Worked perfect. My nylon strap idea didn't work though, it was way to big.
Old Nov 28, 2002 | 03:32 AM
Pic didn't work in last post.
Old Dec 1, 2002 | 08:00 PM
mckenzie's Avatar
WOW, lol, i would NEVER lift the motor out by the tpi. it looks like it worked. did you break/bend any part of the tpi?
Old Dec 1, 2002 | 09:29 PM
Nope, it didn't dent or smash anything. There are some surface scratches from it though but its going in the same way.
Old Dec 1, 2002 | 11:57 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
its not any different than people using carb plates lifting engines out. i didnt think the carb plate was a good idea untill i read in car craft in the tech section about how much the four bolts can hold, its like 14,000+lbs or something crazy like that.
Old Dec 2, 2002 | 06:12 PM
mckenzie's Avatar
you make a good point with the carb plate Liljay. thx, tom
Old Dec 2, 2002 | 07:07 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Hey John, how did you get the car to weigh close to 3100lbs? Just curious to see some methods you used to reduce weight! Nice car, pretty, um, "trick"! Thanks-Bryan
Old Dec 3, 2002 | 11:59 AM
Speartech's Avatar
Bryan,
The car was weighed with the following changes:
No front swaybar
No back seat
No spare or jack
No floormats
No A/C compressor
Weld Draglites (skinnies on front)
Aluminum driveshaft
1/4 tank of gas
Last but not least: Aluminum engine!:lala:
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
