V-10
Old Nov 17, 2002 | 03:21 PM
SuperchargedRS's Avatar
Car: Camaro of course
V-10
I have been wondering if one could swap a viper engine into a thirdgen. I really dont think I would, but it would be nice to know just to know. But if you did swap one in, what would you have to do (assuming the car was like..say a 91 efi)?????
Old Nov 17, 2002 | 04:49 PM
TexasLT1's Avatar
Car: '92 RS
uh, yeah, have you looked at your engine compartment, and then looked at a viper engine compartment? you might notice some problems....
so basically, no chance in hell
Old Nov 18, 2002 | 04:35 AM
no_car_yet's Avatar
my saying is this" any motor can go into any car....for the right price...", i guess with alot of money it could go halfyway back underthe windsheild. you have to remeber the engine is long than a V8 due to two more cylinders stuck on...
Old Nov 18, 2002 | 12:01 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
It could absolutely be done.....you can do anything you want if you have the time, ingenuity and a little cash
yes the viper engine is a little longer (it really isnt that much longer) if you have ever had the nose of a third gen apart you know that there is a TON of room up there....with some careful planning and fabrication you could easily fit a viper engine in a 3rd gen.
youd probably have to fabricate a new radiator support and move it forward, and fabricate a cradle to mount the motor on....i dont really think it would be that hard....but im a glutton for punishment anyways.....other than the exorbitent cost of a viper v10
Old Nov 19, 2002 | 12:57 AM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
the funny thing is, i went down to this little storage area that my college has. and low and behold there were 5 viper motors all sitting on top of this shelf deally. I actually would have been able to grab them if chrysler didn't want them destroyed. imagine what you could do with 5 viper engines.
i would use one as my winshield wiper motor.
Old Nov 19, 2002 | 09:09 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
This is where we differ. I would use one for each wiper
Old Nov 19, 2002 | 10:17 PM
MdFormula350's Avatar
it would be cool to see!!
but something doesnt seem right, hummm what could it be
o yeah a dodge viper engine in a gm thirdgen!
i sure do like it when watching a car show and they show a ford hot rod and when they pop the hood you see a 350 chevy with tpi..
Old Nov 20, 2002 | 08:53 PM
lankchevy_350's Avatar
in one of the truckins a while back they had a pt cruiser with a v10
Old Nov 21, 2002 | 06:44 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
That's correct. I believe it was at SEMA.
Old Nov 21, 2002 | 11:40 PM
jharms's Avatar
I'm putting an Olds. 455 in my Firebird, however if I could do it all over again I wouldn't put an Olds. 455 in my Firebird. To many compatability issues to work out. It's so darn time consuming, which is something I don't have enough of. I wish you the best of luck if you decide to drop that V-10 in it. It's a GREAT motor, no question, but you could make more power, cheaper, from a 454 and wouldn't have to mess with all the funky stuff you know you're going to have to mess with. Motor mounts, trans. mounts, engine bay space, etc. That's my 2 cents.
Old Nov 24, 2002 | 09:31 PM
zerotosixtyV8's Avatar
Car: Camaro
I would imagine all the issues of a viper motor would be similar to stuffing a big block under the hood, although that motor is hellaciously long...
Old Nov 25, 2002 | 05:06 PM
BIGfooMAN's Avatar
hmm... If an LS1 engine is such a pain to get in a 3rd gen I don't even want to know what a v10 swap would be like...
sure would be nice to be able to mock ppl's v8's though... lol
Old Nov 26, 2002 | 07:21 PM
Rage13's Avatar
Car: 89 Firebird
if your already up to 10 mite as well add 2 more, now just need to find a Diablo and "barrow" a few parts, hmm, could possibly figure a way to use the doors too those things are so cool
Old Nov 26, 2002 | 10:02 PM
nbn792's Avatar
For less money you could build a mean aluminum big block engine. Probly cost you less to beef up your car with a new tranny, new rear, ton of susp. work, and build an aluminum BBC then the viper motor alone. By the way, how much would an aluminum big block weigh as apposed to a normal cast iron SBC, lets say both are mild with aluminum heads. now a healthy-wild alumimum BBC in a thirdgen would definitly be more interesting then a viper IMO.
Old Nov 26, 2002 | 10:19 PM
nbn792's Avatar
Sry computer is on the fritz.
Old Nov 26, 2002 | 10:45 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You could build a really wild sbc for $12,200 (from scoggin dickey) w/o all the hassels of fitting it in there.
Old Nov 28, 2002 | 08:14 PM
Car: 1985 Z-28
Engine: a big one
just go and weld two small blocks together and get a v-16
Old Nov 29, 2002 | 07:10 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Good idea! Only problem is that I don't have welding gear. Could I use JB steel weld instead?
Old Nov 29, 2002 | 08:26 PM
SFX099's Avatar
Car: '95 Trans- Am
Engine: 5.7, Baby
Sure, you can use JB Weld, that stuff holds anything. But I think it would probably be cooler to weld 2 Viper V-10's together and put them in the bed of a Duelly. You would be able to pop wheelies in that thing.
Twoelouie1952
Nov 22, 2007 10:54 PM
pandorafowler
Jul 3, 2006 05:53 PM
therckid
Feb 20, 2004 08:04 PM
Mathius
May 30, 2003 09:30 AM
300hpse
Theoretical and Street Racing
Feb 16, 2002 12:42 AM
