View Poll Results: WHICH ASSEMBLY IS THE BEST FOR A SBC 400
SCAT CRANK AND RODS
40.00%
EAGLE CRANK AND RODS
60.00%
Voters: 10. You may not vote on this poll
EAGLE vs SCAT
Old Dec 13, 2002 | 05:58 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
EAGLE vs SCAT
I'm looking into a Crank and Rods for a SBC 400 that will produce about 450-500hp. This will be a street rod with maybe 2 trip to the track for tunining purposes only... I have heard so much about different rotating assemblies that im stuck between a Scat and Eagle. Which one is better of the the two/ or is they both of about equal. I will be using 6.0 Rods and Wiseco Flat Top Forge Pistons.
Thanks for your help
Old Dec 13, 2002 | 06:22 AM
ede's Avatar
ede
i'd avoid scat parts
Old Dec 13, 2002 | 08:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I second that; I'd also look at Lunati
Old Dec 13, 2002 | 07:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My new engine has an Eagle 4340 crank, Scat 4340 I-beam rods with cap bolts and JE floating pistons. I paid extra for the JE instead of SRP pistons because they were much lighter.
The better of the 2 is whatever is the lightest. There are some cranks out there that look like a good deal until you have everything balanced. Pay $1200 for a crank and another $1200 to have it balanced.
Buy quality stuff and pay the extra cost. It's better in the long run. If you can afford it, Lunati parts are the best.
Old Dec 13, 2002 | 09:06 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Hey Stephen,what are you doing with your old setup??(like cam,intake,carb and heads)I have a stock 90' 454 SS right now that needs help
Daz
Old Dec 13, 2002 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I only bought new pistons, rods and a crank.
Cam - reusing
Intake - reusing
Carb - Used for parts to make a hybrid Holley/Demon alcohol carb
Heads - Once they're fixed, reusing.
The only old parts I currently have that can still be reused is a Comp Cams Xtreme Energy cam. The biggest one available. I also have a stock cast crank. It will probably go into another engine if I can find a cheap one with a spun bearing.
Old Dec 14, 2002 | 02:18 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Cam - reusing
Intake - reusing
Can you give me a list of your current engine setup??Im trying to look for basis
Daz
Old Dec 14, 2002 | 10:42 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Basic list:
1974 454 block. Bored .060" line honed, decked, ARP studs hold the bottom end in.
Eagle 4340 crank. Standard 454 stroke.
Scat 4340 rods +.250"
JE 13:1 pistons
Merlin oval port heads. Modified for extra lift (springs, valve guides, valve seals), ported and polished.
Comp Cams 11-613-5 solid cam
Comp pro Magnum 1.7 rockers
Edelbrock Victor Jr intake
Holley 850 alcohol carb
That's about the basics. There are a lot more but you should look at my web site for all the specifics about the car. If there's something you need to know that's not listed on the web site, then just ask. If I can answer it, I will.
I'm guessing the new engine should be making around 650 hp in the spring. I should be able to run mid 10's at altitude but will depend on how well the 9" slicks hook up.
Old Dec 14, 2002 | 01:39 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Basic list:
JE 13:1 pistons
I shouldve said previous setup"maybe"?..lol
If its better for me to start a new thread lemme know..anyways..
I can get the open chamber rectangular heads(stock) just a $150 more than the 781's..Would it be too hard to make this head coupled with a hydraulic cam and 750 CFM carb streetable (w/ AC ) and still produce 500HP@6000-6500?..I can live with driving with 250HP for a year if I know I can get to this goal..And maybe even more (600-650HP range) with the same heads but radical compression,cam,carburation after that
Daz
Old Dec 14, 2002 | 10:35 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
ahhhhh
i guess i'm one of the people that can have a solid opinion of scat stuff from by awful experiance.........
i built a 383 using their 9000 series crank and 4340 i beam rods.... even with a small base circle cam they still had to be grinded a little....
would i use the same setup for a non stroker applicatin?, absolutly!!
the main reason they didn't clear is because they are a beefy rod made for durability...... not strokers....
i think they are a good company and i'm sure they are many others out there that will agree with me also....
but it's your money and if ya can afford the good stuff like mentioned above, go for it.....
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
86z89iroc
Oct 5, 2015 01:04 PM
F-body-fan
Sep 17, 2015 12:16 PM
