v6-v8 again
Old Dec 13, 2002 | 11:08 AM
jesse23's Avatar
v6-v8 again
What are all the parts im gunna be needing to put a 350 or larger in and waht cost for each?
Old Dec 13, 2002 | 12:05 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
well, since you didnt specify what kinda 350, i'm going to assume a 350 TPI
complete engine including all accessories (alt, ps pump, etc) $1500
wiring harness $300
motor mounts $50
headers $200
radiator $200
if you have an automatic, you'll need a new transmission
if you have a manual:
bellhousing $50
flywheel $150
clutch $100
pressure plate $100
clutch fork$30
t.o bearing $15
pilot bearing $3
upper and lower radiator hoses $30
Old Dec 13, 2002 | 06:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The answer to the first part is, "everything on a factory V8 donor car that is different from your V6 car".
The answer to the 2nd part is, "whatever you pay for the factory V8 donor car".
Old Dec 13, 2002 | 07:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The easiest, cheapest way to put a V8 in your 6-cyl car, in 2 easy steps:
1. Sell the 6-cylinder car.
2. Buy a V8 car.
You'll spend somewhere about a third to half as much, have about 0% of the trouble, and you won't have to worry about whether you have the right parts.
Old Dec 14, 2002 | 04:32 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
2. Buy a V8 car.
Words of wisdom!!!
Old Dec 14, 2002 | 05:13 PM
Dirty Rob's Avatar
wiring harness $300
motor mounts $50
headers $200
radiator $200
bellhousing $50
flywheel $150
clutch $100
pressure plate $100
clutch fork$30
t.o bearing $15
pilot bearing $3
Driving a car with an american V8: Priceless
Old Dec 14, 2002 | 05:43 PM
Engine: 406
LMAO!!!!!!
Old Dec 14, 2002 | 09:11 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Oh, come on, where's the fun in swapping v8 to v8?!?:lala:
Old Dec 14, 2002 | 10:18 PM
Engine: 406
well If you are talking Small Block to Big Block,,,,,its all there!!!
86camaro454
Nov 19, 2013 06:26 AM
kelham
Feb 24, 2008 11:16 PM
tourville
Interior Parts Wanted
Nov 6, 2006 09:48 PM
tourville
Oct 27, 2006 05:40 PM
