What do you think of this swap??
Old Dec 27, 2002 | 10:07 PM
thunderChris10's Avatar
-350 CI 2-Bolt Main Block Board .060 Over
-Blocked Hot Tanked, Magna Fluxed and Decked
-Forged Crank w/ Speed Pro High Performance Bearings
-NEW! High Performance GM Truck Rods
-NEW! “Keith Black” Flat Topped Pistons w/ Speed Pro High Compression Rings
-NEW! “Manley” Double Roller Timing Gears and Chain
-NEW! “Lunati” 0.512 Lift Cam w/ Hydraulic Lifters
-NEW! Speed Pro Bearing
-High Volume GM Oil Pump
-Performance Oil Pan w/ windage tray
-Fresh GM cast iron “Fuelie” Heads-full ported and polished with oversized exhaust runners
-“Manley” cast roller rockers
-Stainless steal 5/8th High performance intake and exhaust valves
-Competition aluminum intake
-Race-customized 825CC “Holley” 4-Barrell, double pumper carb
-All new “Fell” –Pro gaskets, seals and plugs
Old Dec 28, 2002 | 02:07 PM
MdFormula350's Avatar
sounds good!!
Old Dec 30, 2002 | 02:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Some people make me so jealous
j/k.. sounds like a good setup to me... gonna sound NASTY when you fire 'er up, hehe
Old Dec 30, 2002 | 02:49 PM
385LT1's Avatar
Should be good for about 400 at the crank....if.......
where are the rest of the specs on that cam....... You listed the lift for 1 lobe , possibly 2.........
what did they deck the block too.........
Cylinder Head specs......... vavle sizes, combustion chamber volume... runner volume.. CFM @ .500" lift
Rod length..........
What ratio Rockers........
Pistons........ what cc valve reliefs
compressed thickness of the headgasket........
Was the rotating assembly balanced.........
ETC..........
You need all this critical info to determine how an engine will run..
Old Dec 30, 2002 | 02:51 PM
87RS402's Avatar
It would be over-carb'd and if your not going to port the intake and use a good exhaust setup the heads will be a waste of money. Never seen 5/8" valves either.
What are the rest of the cam specs, the intake and what in the world do you mean by "High compression rings"?
Old Dec 30, 2002 | 02:54 PM
385LT1's Avatar
LOL.... well galleee..... partner....... these here rings are racin' rings.......Ya know what i mean..... them there special one's that make ya' go fast n' stuff.....
LMAO.........:sillylol:
Old Dec 30, 2002 | 05:06 PM
385LT1's Avatar
Laughing with you, not at you......
Im sure everyone knows you probubly didnt think anybody wanted to see all these specs........ No biggie.......
Old Dec 30, 2002 | 05:24 PM
im not really sure of all the specs on everything... those are jus the things i remember off the top of my head...
Old Dec 31, 2002 | 04:16 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Re: What do you think of this swap??
Originally posted by thunderChris10
- All new “Fell” –Pro gaskets, seals and plugs
I guess I didn't know there was a company named Fell that made pro gaskets.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
