Roller cam question...
Old Dec 29, 2002 | 05:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey, just a simple question...
I have a 350 (L48 i think) that i pulled out of a '79 Z28, rebuilt and put in my '83 a few months ago, and plan on a bunch of modifications for summer. One of them is a new cam.
Here is the question: Can i put a roller cam into this engine, which currently has regular hydraulic lifters? If so, what will i need other than the cam, lifters and pushrods?
Thanks in advance.
Old Dec 29, 2002 | 08:00 PM
ede's Avatar
ede
sure can just get an aftermarket roller set up like hot rodders have been doing years before gm came out with their roller cam
Old Dec 29, 2002 | 11:50 PM
Air_Adam's Avatar
Cool, thanks man... i was pretty sure i could use them, but some people had been telling me i would need stuff to keep the lifters from moving left and right on the cam lobes (wtf?!)
Just wanted to be sure
oh.. can i use the pushrods i already have or do i need new ones?
Old Dec 30, 2002 | 03:30 AM
bjm323's Avatar
Car: '91 Camaro RS
You do need a cam button to keep the cam from walking back and forth if you are going to a roller setup. You need to keep the cam end play around .005 to .008. Also, you may need a bronze distributor gear depending on what the cam gear on the cam shaft is made of. Try to get a cam that has an iron cam gear on it to avoid using a bronze distributor gear on the street.
Old Dec 30, 2002 | 02:25 PM
Air_Adam's Avatar
Sounds cool to me.. thanks BJM
Old Dec 31, 2002 | 06:45 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Im planning the same thing for my SBC 400. Please be aware that you will need the Retro-fit package. That require special lifters and has been back ordered for a while. Changing from a hydraulic to roller setup will cost about $700.
Here is some good information to read about Roller Cams Conversion:
http://www.idavette.net/hib/camcon.htm
Old Jan 2, 2003 | 03:58 AM
Air_Adam's Avatar
Thanks for the warning DTL... I'm glad you told me that... by what could possibly be there that costs $700?!
Old Jan 2, 2003 | 09:38 AM
vwdave's Avatar
Lifters......The lifters cannot rotate at all. If they do, your screwed. But, the retro's have a bar that attaches them so they cannot move.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
