LT1 cam
Old Jan 17, 2003 | 11:44 PM
z86roc28's Avatar
LT1 cam
Is there a such thing as a GM hot cam kit? Is it the same as the LT4 cam kit, if there is one? If so, whats so good about it?
Old Jan 18, 2003 | 12:07 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
The great thing about the GM hotcam kit is the price. The cam and springs com as a complete packege. The LT4 Hot cam will work in your LT1 however I would make sure that the rocker arm ratios between the LT1 and LT4 are not significantly different.
You may also want to consider a COMP CAM Extreme Energy cam with hardened pushrods and 918 springs. This will be more pricy than the hotcam setup, but a better solution in my opinion.
As with any cam swap you must recalibrate your PCM to get optimal performance.
BILL
Old Jan 18, 2003 | 09:12 AM
TheViking's Avatar
The LT4 Hot Cam kit comes with 1.6 roller rockers.
Ron L.
Old Jan 18, 2003 | 07:08 PM
z86roc28's Avatar
Anyone everused the TPIS zz-9 cam, they say they improved the design over the gm zz-3 cam.....well? worth the $375????
Old Jan 18, 2003 | 07:17 PM
z86roc28's Avatar
And where can I find the specs for gm aftermarket cams?
Old Jan 18, 2003 | 07:49 PM
Makaveli's Avatar
go to www.sdpc2000.com, they have a lot of cams there... just go to engine components on the side bar n follow through till u get what you need... their catalog spreads it out a little more easier than their site in my opinion though, so its easier to compare hehe
Old Jan 18, 2003 | 10:34 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I had the HOT cam in my 96 WS6. It was a great all around cam. I passed the IM240 emissions test. Got 20+mpg all the time. And the car ran a best of 12.4@111.
There are plenty of cams that will outpower it but few that are as "stockish" as this one is.
Old Jan 18, 2003 | 11:11 PM
z86roc28's Avatar
Rob, does that GTA have an LT1 in it?
Old Jan 19, 2003 | 06:44 AM
TTA 1387's Avatar
What GTA?
Old Jan 19, 2003 | 01:32 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Something to note, the LT4 hotcam springs will not fit in your iron heads without opening up the spring seats. You can get aftermarket equivalents that will fit in there without the machining.
The LT4 hot cam is 'larger' than the lt4 regular cam, hence the hot.
Old Jan 19, 2003 | 02:21 PM
z86roc28's Avatar
Ahhhh, so the LT4 hot cam is an upgrade even for the LT4? And where do i find those springs.....
Old Jan 19, 2003 | 02:25 PM
z86roc28's Avatar
You know what Rob, i have a bad habbit of overlooking details that i have ro break....you had the 96 with the LT1 and now the TTA, not GTA...oooops. What else did u have done to the LT1 to make it go 12.4....stick or auto? what gears? Stall speed if auto? Other mods?
Old Jan 19, 2003 | 04:27 PM
TTA 1387's Avatar
Here's a basic web page of my old car:
http://users.adelphia.net/~tta1387/cars/ws6.htm
It has all the mods that were done to the car.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
