Where to buy Complete 350 tpi swap...
Old Jan 22, 2003 | 06:20 PM
E.T.'s Avatar
Hey guys, I have a slow a$$ 305 tpi in my camaro and i want to swap in a 350 tpi. what all must i do to do this. Also where can i get a complete 350 tpi with engine harness off the net.
Thanks.
Old Jan 22, 2003 | 07:54 PM
E.T.'s Avatar
Could i use the wiring harness from the 305 for the swap and just get the motor and ecu. Oh yeah, would the tranny be able to handle the 350.
thanks.
Old Jan 22, 2003 | 08:08 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you dont need a new harness, just a 350 long block, new knock sensor and 350 spec injectors
thatsaboutit
Old Jan 22, 2003 | 09:08 PM
E.T.'s Avatar
How about the ecu can i just use the stock on?
Old Jan 23, 2003 | 07:17 AM
85TPI400's Avatar
Yes, you can use the stock computer but if you are going to use 350 injectors you should also get a new prom.
Old Jan 26, 2003 | 05:17 PM
E.T.'s Avatar
Wouldn't it be easier to just use the Ecu that came from the car in which the engine came out of. I think it would.
Old Jan 27, 2003 | 04:02 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
what about MAF or speed density setup? Would that be a problem?
Terrell351
Jun 13, 2021 01:13 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
