350 .30 overbore
Old Feb 2, 2003 | 06:20 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
350 .30 overbore
I was wondering roughly how much it would cost to get a 350 block bored .30 over at a machine shop.
Old Feb 2, 2003 | 07:13 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my 400 cost about $450. mine was bored .040 over. the cost included hot tanking the block, heads, oil pan, balancer and timing cover as well as the boring.the guy also checked for cracks and made sure everything was straight. hope this helps
Old Feb 2, 2003 | 07:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Varies widely from place to place, and from one kind of machine shop to another.
If you just go down to your corner parts store, it will probably be around $15-20 a hole to bore and hone it. On the other hand, if you go to a racing machine shop and have it done right, bored on the exact design centers exactly perpendicular to the crank with a torque plate, expect to pay $75-100 more.
Old Feb 2, 2003 | 07:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The ElCheapo way is $15-$20 per hole to be bored and honed to size.
To get it done properly the block should be hot tanked, new cam bearings, decked to make sure the deck is square and it should be bored using torque plates. Having it line honed is also recommended but not always required.
It doesn't cost any different if it's bored out .030 or .060"
Old Feb 4, 2003 | 05:25 AM
85TPI400's Avatar
If this is a junkyard block, The problem is you dont know what you have and most machine shops dont want to just bore a block, They usually want to clean, magnaflux, surface the deck, tap all holes, install new freeze plugs and cam bearings and bore and hone. (usually around $300.00 in CA) after that it it shows any sing of spun bearings they will try to sell you a line hone in addition for an additional $125-150.00. Be careful who you deal with and find a reputable shop. When it comes to this subject, You usually get what you pay for.
Good luck,
Tony
Old Feb 4, 2003 | 10:27 AM
ede's Avatar
ede
damn my machine shop charges 8 dollars a hole and that's with torque plate. the do reguire cleaning so there's another 50 plus freeze plugs are 15 and 10 to install and cam bearingsare 25 plus 30 or 35 to install. about the only advantage to living where i do, labor rates haven't caught up to the rest of the country.
Old Feb 9, 2003 | 11:37 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
shoot.... for $300 i bought a 4 bolt 350 block from a guy who runs a machine shop up here bored .030 over honed, new freeze plugs and cam bearings... bored and such with torque plate... i think i got a deal:lala:
Old Feb 11, 2003 | 11:39 PM
Camarokid01's Avatar
My dad owns a machine shop here in Virginia, I dont know where you are from though, but if you have any certain questions let me know and I will ask him.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
