305 to 350 swap/ high RPM bog
Old Feb 21, 2003 | 05:18 PM
Sunset01SS's Avatar
My friend has a 86 Z28 which had a stock carburated 305. He yanked it and installed a GMPP 350 h.o. crate motor and bolted all the 305 components onto the short block. Most of the time the car bogs at higher RPMs. Seems like it isn't getting enough fuel or the timing isn't being set properly. Has anyone encountered the same problem? Is it the carb? Distributor? Fuel pump? ECM? Any help would be appreciated.
Old Feb 21, 2003 | 05:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Start with fuel filter (if not already replaced). Then fuel pump. Could also be a clogged pick-up sock in the fuel tank.
Some of these cars also go an electric pump in the tank. If it is shot, the mechanical will have a hard time keeping up.
Old Feb 21, 2003 | 05:45 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
sounds like a lack of fuel to me too. unfortunately, im not that good with carbs, but when i put my 350 HO in, i had a similar problem.
just check everything, including the pump, etc.
-brian
Old Feb 24, 2003 | 10:37 AM
Sunset01SS's Avatar
Do you think it is a fuel delivery problem, or do you think my friend needs a bigger carb? It's the stock 305 carb.
Old Feb 24, 2003 | 12:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, I'd start with a new fuel filter, which is inside the fuel inlet nut on the front of the carb, where the fuel line goes into it.
Old Feb 24, 2003 | 02:32 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i know NOTHING about carbs, so I don't know...but, I would check on the carb board to see what they may have to offer. I know that a few guys over there know a LOT about that stuff.
-B
Old Feb 24, 2003 | 07:47 PM
chymos's Avatar
stock 305 carb = LG4
change the exhaust
my car had the same engine.....and from looking at the exhaust manifolds, that has *got* to be one of the most restrictive designs GM ever dreamed up....and all done for emissions purposes (I think)
anyway, if the exhaust is too restrictive, I could possibly see it bogging slightly at high RPM, particularly if the catalytic converter is getting clogged....though I'm by no means an expert, so don't quote me on that
plus going from completely stock LG4 to a "high output" 350 means the exhaust is choking the engine even more
Old Mar 1, 2003 | 09:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, its probably a combination of lack of fuel (like said above) and a very restrictive exhaust system.
Old Mar 2, 2003 | 05:32 PM
Pontiacman's Avatar
You have to tune the carb for the bigger engine. Also a bigger exhaust for the increased flow
Old Mar 2, 2003 | 07:31 PM
86bird's Avatar
High rpm bog
I had a similar problem with my 86 T/A after a 305-350 HO swap. The solution was to add an electric fuel pump back by the fuel tank to act as a booster for the mechanical pump. The mechanical pump will regulate the final pressure to the carb. The car use to fall flat @ 4500 rpm in second gear, now it pulls strong to 6000.
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
st.evel07
Aug 13, 2015 06:15 PM
killer777
Aug 8, 2015 02:47 PM
