motor mounts and fuel pumps and trannies ohh my
Old Mar 2, 2003 | 12:21 AM
eddie header's Avatar
ok dudes heres the deal project "red comet" has just had its silly little v-6 removed and now its time to get down to the real work ive decided to go with a 305/350 bolted to a th400 with a limited slip torque converter and i was just wondering if anyone has done that yet and i was wodnering if u ran into complications in this... also since im going with a carbed engine what type of fuel pump should i put in there
thanks for ur time
Old Mar 2, 2003 | 07:05 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Do a search!!!!!!!!!!!!!!!!!!!!!! THis type of thing has been done before!!!!!!!!!!!!!!!!!!!!!
Old Mar 2, 2003 | 09:37 PM
black83z's Avatar
Not sure what a limited slip converter is. Since you are considering a 305/350, why do you want a non-overdrive transmission? And why a th400? Do a search before asking, this has been done many times.
matt
Old Mar 3, 2003 | 08:36 PM
PhilM's Avatar
Car: Accepting applications...
maybe it is easier nowadays to just post something new instead of searching...
but anyway, why the 400? if it is an all out drag car or sees limited duty, go with a 3 speed, but use a th350. lighter, less power to turn it. if it is a street car get the overdrive.
Old Mar 4, 2003 | 04:35 PM
black83z's Avatar
I concur with the transmission assesment. I do not think that you are considering an all out drag car with a 305, tho, are you? I would suggest a built 700r4, overdrive is incredibly nice to have. Especially with gears. Just a suggestion.
matt
Old Mar 4, 2003 | 06:42 PM
hanks guy ive reconsidered my transmision selection and have decided to go with the 700r4 tranny.... now one thing im worried about is motor mount.... now i know i have to replace the engine part of the mounts but what about the frame part of the mounts and is there any frame modifications that have to be done.... i.e welding cutting or others
thanks for ur time
Old Mar 5, 2003 | 09:22 PM
black83z's Avatar
do a search and waste your time instead of ours
Old Mar 6, 2003 | 08:54 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hey now play nice
Old Mar 6, 2003 | 09:09 AM
black83z's Avatar
Not trying to sound mean, just busy. didnt mean to offend
matt
Old Mar 6, 2003 | 10:42 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Limited slip torque converter?... Does he mean a limited-slip rear-end?
Now I'm all confused....
Old Mar 6, 2003 | 04:16 PM
black83z's Avatar
Never heard of a transmission with a posi. Mayhap a torque converter that slips until a certain rpm? Perhaps a ....stall speed?:lala:
Old Mar 6, 2003 | 08:46 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
get the mounts for a v-8 from a parts store and put them in the factory holes just forward of the ones your v-6 mounts are currently in.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Elliswon
Aug 10, 2015 12:33 PM
