Looking for all aluminum big block
Old Mar 24, 2003 | 12:22 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
Does anybody have a link to a shop that makes aluminum BBC engines? If you do please post it...Thanks.
Old Mar 24, 2003 | 01:45 PM
ede's Avatar
ede
rodac and aris, rodac is a wedge and aris is a hemi. i think mike koskey was running olds heads on a rodac with pretty good sucess.
Old Mar 24, 2003 | 06:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
www.cncblock.com Has some really nice ****.
Old Mar 24, 2003 | 06:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
GM makes (or will be making) an aluminum big block. They are ressurcting the ZL1 (all aluminum 427)
Old Mar 24, 2003 | 11:33 PM
Charlo's Avatar
ZL1 block is for sale at sdpc2000.com $5100 i think.
Charlo
Old Mar 26, 2003 | 02:20 AM
Car: Formula
Engine: 5.0L
Wow, that ZL1 block is looking mighty tempting...thanks for all the help.:hail:
Old Mar 26, 2003 | 05:46 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Depending on what you are looking for. We've got a Keith Black B1 headed motor for sale for 12500 complete pan to carb. Makes 800hp on motor, 1200hp on single stage and 1400hp with the second stage. Motor was just freshened.
Pics of the motor are on my site at www.koolmeister.com
The reason for selling is we switched to a BAE Mike Janis www.jancen.com built 526 hemi for this year. Pics of the new setup are at www.insanityracing.com
Miles
Old Apr 1, 2003 | 06:39 PM
RoadRacer's Avatar
Donovan is HITHERE widely used supplier of aluminum blocks in racing circles. Like anything though, they're expensive.
Old Apr 2, 2003 | 06:44 PM
Parrydise7's Avatar
Do you have money to burn? If so, check out GM's new Ram Jet ZL1, limited edition fuel injected ZL1 454. I didn't find it on their web site, but it is listed in the latest performance parts catalog. Here's what the catalog says:
"With only 200 planned for production, the Ram Jet ZL1 is sure to be a highly sought item....
"The ZL1 makes serious power, with 520 horsepower on tap thanks to 10.2 to 1 compression ratio...
"The Ram Jet ZL1 uses GMPP's RAm Jet fuel injection originally introduced on the Ram Jet 502.
BTW. the torque rating isn't far behind the horsepower at 493.
Needless to say, there is no price listed. Your dealer will be happy to gouge you for every penny on this one.
:hail:
Old Apr 3, 2003 | 02:32 AM
Car: Formula
Engine: 5.0L
Yeah, definetly don't have money to burn (yet). Anyways, I intend to build my own engine, that way I know it is done right...and if not , I have nobody to blame but my self. 520 out of a 454 sounds a little low. If it was assembled correctly, with the right attention to parts prep and oiling efficiency, there should be no reason why they couldn't top 600hp and still run on pump gas. Sounds fishy to me. Just my $.02
Old Apr 5, 2003 | 07:12 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
whats the benefit in having an aluminum block, rather then whatever it is now
Old Apr 5, 2003 | 07:33 PM
Car: Formula
Engine: 5.0L
Well the most obvious benefit is weight...the ZL1 427 BBC that I am looking at weighs only 110lbs(block only). This will help with the fornt/back weight distribution. I think that one draw back of aluminum is a lower Thermal efficiency percentage but I'm not totally sure on that one. All in all, aluminum will lower your power to weight ratio, which in turn makes your car faster.
As I said in another thread; an aluminum block on our cars will lighten up the front end which is good for autocross. This reduces understeer while cornering, not to mention lowering weight to give the tires an easier time finding grip.
The engine that comes stock in our cars is cast iron which is good for drag racing because you don't really have to worry about how much weight is on the front wheels. In drag racing you can stuff the biggest engine you can between the tires and maximize weight transfer for a good lauch. In autocross an almost 50/50 front/back side/side weight didtribution and almost no wieght transfer is necessary for good handling characteristics.
A bit long winded but I hope this helps
Old Apr 5, 2003 | 09:41 PM
Air_Adam's Avatar
a BBC with an aluminum block typically weighs LESS than the usual SBC.
Old Apr 6, 2003 | 03:26 PM
Car: 1984 Z28
ohhhh. well i figured the weight difference obviously but i never knew that other crap. whats BBC and SBC i thought BBC was Big Block ????
Old Apr 7, 2003 | 12:13 PM
Car: Formula
Engine: 5.0L
SBC=small block chevy
BBC=big block chevy
Old Apr 7, 2003 | 02:26 PM
Car: 1984 Z28
i should hav eknown
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
