will 454 fit in car??? PLEASE HELP!!!!!!
Old Apr 1, 2003 | 09:21 PM
Btlfedls1's Avatar
HITHERE have HITHERE 99 ss as seen in sig and know nothing about you guys cars. HITHERE want to build HITHERE street legal race car to stop breaking my good car. HITHERE am wondering about stuffing HITHERE built 454, turbo 400, and HITHERE 12 bolt in HITHERE late 80's iroc. Is this HITHERE easy swap . Any info would help and HITHERE hope to post alot on this board in the up coming months. thanks mario
Old Apr 2, 2003 | 07:22 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have what you're talking about. Big block, TH400, and 12 bolt.
There are 12 bolts on the market that bolt right in or if you're talented you can weld on the brackets and torque arm mount yourself. I have the Strange Engineering 12 bolt with the Superposi and 3.73 gears.
TH400 fits in the tranny tunnel. TH400 with tranny blanket does not. The TH400 does not accept the factory torque arm so you will likely want to buy an aftermarket torque arm and tranny crossmember combo that mounts the torque arm to the frame where it belongs. Of course, you'll need a custom driveline with the TH400.
Big block drops right in on the small block V8 mounts. Some people have trouble with tall valve covers clearing the wiper motor and air conditioning. I have to run tall valve covers because I use 1.7 roller rockers but have no clearance issues with the wiper arm. I don't know of any person successfully using tall valve covers with air conditioning.
The worst part of the swap is exhaust. Header options are very limited and you'll spend about $800 before you get a set that fits right. The Hooker SuperComps do NOT fit worth crap. But most people use them because of cost.
Old Apr 3, 2003 | 03:27 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It's all on my page at www.koolmeister.com
Miles
Old Apr 3, 2003 | 06:51 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Miles
hey Miles,here's the reminder for thie pics
Daz
Old Aug 31, 2003 | 11:27 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok so the motor will fit in the stock location. Could a probuilt 700r4 be used? Without moving the tranny back or getting a new crossmember? Special driveshaft needed?
Old Sep 1, 2003 | 08:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
Yes, you could use any builder's 700 for that matter.
No you don't have to move the trans anywhere, it remains in the stock location.
No special drve shaft is needed. Although, by the time you get done with a swap like this, getting a drive shaft made to your required length will be the very least of your worries; you walk into a drive shaft shop with you old one, hand it to them and say "make this x inches long"; and about $75 and 2 hours later, you're done with it.
Old Sep 1, 2003 | 08:50 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
What youre gonna have problems with is the power steering bracket and the clearance between the pulleys and the electric fans(for dual fan cars).The short valve covers fit my Comp Magnum roller rockers..The hooker headers wasnt too bad of a fit.The old style Spohn SFC's that I have have to be cut 6" though.BTW the power steering pump were hitting the steering box as well...
more pics here
HERE
Daz
Old Sep 1, 2003 | 12:28 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I see you still have all your air conditioning in tact but your compressor, do you think i would be able to fit my compressor in my car? becasue i really want the luxory of air, i dont care how much power it takes because i already have enuff. ha ha. the more info the better. I will be running power steering like Daz, and i guessss i will be gettin some short valve covers.
Old Sep 1, 2003 | 03:24 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
It doesnt clear the hood or valve covers...
Im pretty sure theres a way..but its not worth it at this point in my build up
Daz
Old Sep 2, 2003 | 10:18 PM
Transmission: 4l60e
So basically its almost a direct swap. Most people don't seem to think its worth it. It would definetly be different. Ive never personally seen a big block thirdgen. It would be different but a nice 400 would probably be much easier and just about make the power./
Old Sep 3, 2003 | 05:49 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
BTW Daz, that engine looks great in the car, wish i could get mine in, but the dang machine shop takes to long.
Old Sep 3, 2003 | 07:55 PM
1984 trans/am's Avatar
my pic
Old Sep 3, 2003 | 07:56 PM
not a big block, but...
Old Sep 4, 2003 | 02:00 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
hhhoooooollllllllyyyyy ffffffrrrrrreeeeaaaaaakkkkkkkiiiiiinnnnn cccrrrapppppppppp!
dude.....i want that car......well, the engine itself would be nice......damn! whos is that!?
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
