View Poll Results: Should I build the 350 or the 454?
454
59.09%
350
31.82%
Leave the 305 (yeah, right...)
9.09%
Voters: 22. You may not vote on this poll
BBC or SBC??? What you you think?
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
My brother has 2 engine blocks in his garage, a 350 and a 454. He said I can pick one and I can have the block. My question is should I spend the big bucks and build the 454 or do the 350 and still have some coin in my pocket? Gas-mileage is not an issue because I live about 5 miles from here I work.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Threre is a guy around here with a 502 in his camaro.. pretty good for wow factor.. The question is can you handle the HP, new trannies, rear ends, driveshafts, etc, all would be in your future.. Not to say theywouldn't with a stout 350 though either..
Are you just interested in the engine or do you have other aspects of the car to work on?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
As cramped as the engine bay is I wouldn't have thought you could get a 454 in our engine bays.
If you want to go in a straight line as fast as possible then go for the BBC. It will fit, and there is plenty of info on these boards that will help you.
However, if you want to have a good handling car then think carefully about what you are doing. You'll be taking an already front heavy car and making it even more so.
Car: 1986 Z28
Engine: 355
Transmission: th400
I'd go with the small block. Cheaper, Lighter, are easier on parts, and last longer in high power applications. Unless you wanna run below like 10.00NA i'd stay with the small block.
Car: '89 Firebird
Engine: 7.0L
Originally posted by Pony Killer
I'd go with the small block... last longer in high power applications.
Engine: 350ci V8
I appreciate your insight, guys. I decided I'm gonna build the 350. That will be plenty of power for now. If I want more power later, I'll probably just put it on the bottle... Thanks again.
Engine: 350ci V8
I was thinking about punching the block .030"-over and using a forged rotating assembly. Ported Vortech heads. 1.6 roller rockers, and a few other things to be decided later. And, as always, opinions and suggestions are appreciated so let me know what you think.
Car: '85 Z28
Transmission: WC T5, 3.23 posi
That's a good combonation right there. Add a Comp XE274 cam and Performer RPM intake and you'll be pushing 400+hp and knocking down mid 12's with traction.
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Damon
Sep 26, 2015 04:29 PM
454 buddy!
