LO8 AND LG4 are they the same?
Old Apr 27, 2003 | 01:20 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
is it just that the LO8 is Tbi and the LG4 is carb and pont and maro? thnks
Old Apr 27, 2003 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THe L03 and LG4 are both 305s, and both are the bottom model V8 in their respective years. They have the same cam. Heads are different: L03 ones are terrible and hopeless, LG4 ones while terrible in stock form are at least workable.
Old Apr 27, 2003 | 05:27 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
The LO8 is a 5.7 TBI that was used in Caprice Classics and other full size GM models.
Old Apr 28, 2003 | 07:19 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Ok thnks And I meant LO3 oops so is it worth it to put my LG4 heads on it? thnks Kev
Old Apr 28, 2003 | 08:21 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
LG4 heads are ALOT better than L03 heads
Lo3 heads are garbage, while LG4 heads are very close to L98 heads flow-wise
Old Apr 28, 2003 | 08:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You will get vastly better results if you fix the other bottlencks of the L03: the exhaust, all the way from teh heads to the street; and the "peanut" cam; and do a mild porting job (bowl cleanup above all else) to the heads.
For exhaust, get a chassis-specific system for one of these cars, but not for the L03; I'd suggest looking up the one for a 88 350 TPI. You'll need the headers with their Y-pipe, a high-flow cat, and a cat-back exhaust, none of which will be compatible with any of the L03 stuff that's there now. Every piece of that needs to go in the trash.
Old Apr 28, 2003 | 09:49 AM
SHAGME's Avatar
Car: 1988 IROC-Z
cool thnks I have the headers and y pipe on order already I already have a flomaster cat back. I dont know what cam yet. The bottom end of the motor was redone 15,000mi ago. new crank rods and pistons. the top end has 124000mi on it but they dont matter anyway since Ill out the LG4 heads on the have 40000 on them. and itll be carbed by the rochester or an edelbrock 750 thnks
Old Apr 29, 2003 | 08:48 AM
SHAGME's Avatar
Car: 1988 IROC-Z
does anyone have a cam to recommend for this set? thnks
Old Apr 29, 2003 | 11:42 PM
ilikerocks's Avatar
i wouldnt ditch the TBI less you planned on going to very high hp levels, ultimate tbi mods, and a new tbi intake help your tbi motor run alot better, and with those heads and exhaust, even better
Old Apr 29, 2003 | 11:51 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
grab an LT1 cam, they really wake the LO3 up.
Old Apr 30, 2003 | 08:08 AM
SHAGME's Avatar
Car: 1988 IROC-Z
OK thnks guys I will be getting it all done soon
Old Apr 30, 2003 | 10:09 PM
SHAGME's Avatar
Car: 1988 IROC-Z
I guess everyone thinks that is the best option for me with that motor? my Z28 is carbed. and I dont care about smog equip or anything. thnks Kev.
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
