Dyno Tests
Old May 13, 2003 | 01:51 PM
kdgreen's Avatar
Dyno Tests
Got my car Dyno'd last night-287.8 at the rear wheels.
I don't guess that is too bad from a 350 .30 over
with 700R4 Tranny and 3.42 gear.
Old May 13, 2003 | 01:52 PM
kdgreen's Avatar
Pic #2
Old May 13, 2003 | 04:27 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
According to the rule of thumb- 20% drivetrain loss- that works out to 359.75 (or 360 HP).
Pretty gosh darn good if ya ask me.
What cam/heads/exhaust , etc., etc. are you running?
Old May 13, 2003 | 04:47 PM
kdgreen's Avatar
I am running Comp XE274-H Cam/springs/lifters
Vortec Heads From Chevy Truck-Ported/Gasket Matched With 2.02/1.60 Valves
I have Flowtech(yeah I know but money was running low) headers into 2 3/4 pipe all the way back to Flowmaster 80 series Muffler with single input/dual out.
Old May 13, 2003 | 11:25 PM
AJ_92RS's Avatar
Cool.
What stall TC? I'm really curious because it looks to be VERY streetable, which is what I'm doing with my 350 build up.
I see you're running a Edelbrock carb. What model? 1407?
Thanks for the info, and good job.
Old May 14, 2003 | 09:47 AM
kdgreen's Avatar
I am running the TCI 2200 Stall. I also have the Edelbrock 1406
600CFM Carb. It works very good. I used the factory fuel pump and mallory regulator with 5 psi fuel to the carb. I went to the 50,000 volt distributor and could really tell the difference in idle. Mine idles around 900 rpm and the whole car shakes. It is really cool at night you can see the headlights bouncing side to side and all you hear is the cam hitting. Really a hit at Sonic drive in night.
:rockon:
Old Sep 18, 2003 | 11:24 AM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
what
i still cant believe that..350 hp/350 ci with a 600 cfm carb.
I AM in a big dilema because I just bought a 600cfm edelbrock perfromer series carb for my 350 but everyone is telling me to go to 750.
I have 1.94/1.60 valves and comp cams xe262h cam.
Is 600 sufficient enough??? for lower rpm power like peak around 3500-4000?
Old Sep 18, 2003 | 01:32 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
the 600 will be sufficient but you WILL make more power with a 750cfm
Old Jan 1, 2004 | 02:21 AM
Car: 82 T/A
ya
ya sure it will but at rpms way higher than the cam makes actual main power at
Old Jan 1, 2004 | 09:07 AM
pskel350's Avatar
i dyno'd at just a few more hp then kdgreen, with a 350 and a 650 carb. i actually gained a ton of hp going from a 750 to 650 carb. the smaller carb, gave me more power, better drivabilty, and gas milage stayed about the same.
IMO a 600 or 650 is pletty for a mild 350
Old Jan 2, 2004 | 03:01 AM
AJ_92RS's Avatar
If you must know...
Here's a chart I compiled from info at www.ChevyHiPerformance.com in the Tech Articles section...
Old Jan 2, 2004 | 08:04 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Thats one of the things that has always made me laugh, almost everyone who has even a stock 350 thinks they need a 750cfm.
Old Jan 2, 2004 | 11:09 AM
AJ_92RS's Avatar
It's the "bigger is better" thinking.
If you think it's difficult to convince young hot rodders that it's not true, you should have seen me trying to convince the ladies.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
