70' chevy 307 swap question.
I have the 305tbi out, Im keeping the T5 but the flywheel does not fit the 307 since it is a 2pc rear main. The 307 was on my nova with a 350trans. My question is what flywheel to use? Did early thirdgen gens come with T5 and 2pc rear main small blocks?
Thanks for all the help.
Renzo
Renzo
Transmission: 4L80E/4L80E
The flywheel from any f-body '82-'85 V8 manual tranny would work.
THose flywheels are tough to find. cuz those cars that you are looking for are crushed. believe me, i checked out 7 yards here in ohio, until i bought a new one instead. You will need a flywheel with 153 teeth with a mounting hole of about 2.5". good luck.
Originally posted by Air_Adam
Just outta curiosity... why a 307?
Originally posted by '82 Beater
... even the most anemic 350 (like mine) will stomp a 307.
The reason I went with the 307 instead of a 350 was because I had the engine in my nova with only 8k miles on the rebuild. Also this 307 is putting more power than a comparable 73'-up 350. I was actually going to sell the camaro with the weak 305 to finish my 454 but I decided that with the gas prices and having the 307 ready to go. The camaro was the perfect choice for a nice daily driver. The nova will just have to wait until after summer.
Renzo
P.S. Thanks for all the help I did find the flywheel. I actually got it off a friend that had it in a 350 78' camaro with a T5. He hooked it up for $40 and threw in a decent performance cutch. Thanks again guys.
Renzo
If you're going through all the trouble anyway, 350's are cheap and easy to find...
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
ou've got one part right. 307's can be had for way less than a comparable 350.
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
