Just some engine pics....
Old Jun 27, 2003 | 11:00 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Just wanted to post some pics of my 350 build. I am replacing my '86 Iroc 305 with a 350. Block is a '79 4 bolt main, L98 iron heads heads ported to a Felpro 1206 intake gasket, Comp Cams Pro Magnum 1.52 roller rockers, Comp Cams XE 268 cam, Accel intake base ported to Felpro 1206 to be replaced by a Holley Stealth Ram once I get it running on the TPI, Holley Flowtech headers.
Speed Pro Hypereutectic Pistons
Old Jun 27, 2003 | 11:01 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
home ported L98 iron heads
Old Jun 27, 2003 | 11:02 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Pro Magnum roller rockers
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
what happens when you try to run pushrods for a roller cam on a non roller cam motor.
Old Jun 27, 2003 | 11:03 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Old Jun 27, 2003 | 11:04 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Old Jun 27, 2003 | 11:05 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Felpro one-piece oil pan gasket
Old Jun 28, 2003 | 01:16 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Umm... maybe I missed something... but why are all your rockers at the exact same angle? Is there no cam in there?
Old Jun 28, 2003 | 01:45 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Just hadn't tightened them down yet in that pic!
Old Jun 28, 2003 | 12:24 PM
MdFormula350's Avatar
looks great. what kinda power do you expect?
Old Jun 29, 2003 | 06:42 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Don't really know. Until I put the Stealth Ram on, the stock runners and plenum will hold me back some. Other than that, these are still stock heads with some port work done and those Flowtech headers are only 1.5" primaries and 2.5" collectors, but they're better than manifolds I figure. Doubt I'll see over 300 (especially until I get that Stealth Ram on), just a stab in the dark at 275 or so (probably less than that).
Finally got the Accel intake on...... waitin' on header bolts....
Old Jun 29, 2003 | 06:43 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
another......
Old Jun 29, 2003 | 06:44 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
all that port work paid off.....
Old Jun 29, 2003 | 08:35 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Nice job. That stealth ram and intake will make that thing rock. Too bad those heads will be holding you back. Post pics and driving inmpressions when you get it running.
Old Jun 30, 2003 | 10:48 AM
91blackgta's Avatar
Those fel-pro one piece oil pan gaskets are nice. I have one on my 350, never leaks.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
