400sbc is it for me?
Old Jul 3, 2003 | 10:34 PM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
I came across a 400sb for $400 what all do you need to do thats different then a 350 i know you have to drill steam holes in the cylinder heads what else do you need i have edelbrock performer rpm heads 70cc would that be good for a 400? please help thanks
Old Jul 3, 2003 | 10:43 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
yup..
Old Jul 3, 2003 | 10:44 PM
Car: 85Z28
yup what...?
Old Jul 3, 2003 | 10:52 PM
Car: 85Z28
is 70cc heads big enough for the 400 and i was thinkin 1.6 rollers
Old Jul 3, 2003 | 11:02 PM
Engine: 406
Re: 400sbc is it for me?
Originally posted by 5.7Camaroboy
Ii have edelbrock performer rpm heads 70cc would that be good for a 400? please help thanks
Yup!!
Old Jul 3, 2003 | 11:04 PM
Engine: 406
depending on the cam you use..1.5's could be ok...
Old Jul 3, 2003 | 11:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im assuming thats a seperate question....
everything else will work fine and bolt up... slight exceptions that may or may not effect you:
1. the stroke is large, so if you plan on using a cast oil pan, it probly wont fit. check for clearance on any non stock 400 pans.
2 the dipstick is on the drivers side... so you will need a oil pan with it on that side
3 as you mentioned, the heads need steam holes.....
4 because its externally balanced, you need a 400 hormonic balencer that has the counter weight in it. you also need a 400 flywheel or flexplate. they have the proper counterweight on them.
i think thats about it. everything else will bolt up, and the external demensions are identical to any other SBC.
Old Jul 4, 2003 | 05:46 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Most important have the rotating assembly balance. This is a MUST>>>>
Old Jul 4, 2003 | 08:02 PM
Car: 85Z28
thanks for the help guys
Old Jul 5, 2003 | 06:07 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
see sig
Old Jul 7, 2003 | 11:17 PM
Car: 85Z28
I bought a 400 and took it apart today its on the engine stand,just pistons rods and crank are in the exept for number 8 rod.
Old Jul 7, 2003 | 11:33 PM
LilJayV10's Avatar
Engine: 406 Roller
What do you mean except for the #8 rod?
Old Jul 7, 2003 | 11:36 PM
Car: 85Z28
it was busted i took it out #8 rod and piston out of the 8th cylinder
evilstuie
Jan 9, 2020 08:29 PM
88TPIZ
Dec 23, 2005 03:07 PM
1986CamaroSC
Feb 23, 2004 01:44 PM
scott87conv
Mar 13, 2001 04:17 PM
Dan84SC
Oct 13, 2000 01:00 AM
