88 Irocz 305 Tpi
Old Jul 4, 2003 | 11:34 PM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
88 Irocz 305 Tpi
I'm looking for some advice. I currently own a 1988 Chevy Iroc-Z convertible with a 305 TPI. However the motor is on its last leg due to the following mods: 100 NOS, Paxton Supercharger and all the available bolt on mods without having to remove the heads from the 52mm Throttle Body to the Flowmaster Exhaust. The car still runs strong in the 1/4 averaging times around 12.8's squeezing into second gear without slicks. Although one major problem is when the car is parked for at least a couple of hours when I return and start it up it blows white smoke. I'm not quite sure what the problem is. But it doesn't appear to burn oil. I'm interested in replacing the motor with a 350HO. Unfortunately due to my recent layoff from my job my budget is tight. I originally wanted a ZZ4 or LT1. What would you recommend. All feedback is welcome. Thanks in advance. Also if anyone is located in the Southern California and is willing to help (willing to pay) please let me know.
Old Jul 4, 2003 | 11:42 PM
Guest
Guest
Posts: n/a
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2421541469
and its a 4 bolt main. :-d i was goign to buy it but i found out today all that was worng with my car was a blown head gasket
Old Jul 5, 2003 | 12:08 AM
IrocZonNos's Avatar
It's not a blown head gasket... It still runs strong. Smokes at start up (about a second or two) only after sitting for a a while.
Old Jul 5, 2003 | 12:11 AM
Guest
Guest
Posts: n/a
what color smoke? white or bacl or a tint of blue?
Old Jul 5, 2003 | 12:14 AM
IrocZonNos's Avatar
Whit'iss
Old Jul 5, 2003 | 12:15 AM
Guest
Guest
Posts: n/a
white it normaly anti-frezze burning but it should also be that the car is runnng to rich?? i don't know
Old Jul 5, 2003 | 08:59 AM
Metaldrgn's Avatar
Car: Yukon, Tahoe, Expedition, JGC
could be tranny fluid, I know of a guy that's having that problem with a truck. That's what my step dad said though.
Old Jul 6, 2003 | 06:08 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
My 305 tpi always gives a little "puff" of blue smoke if i havent used the car in a couple of days, i dont think thats something bad what do you think?
Old Jul 6, 2003 | 07:57 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Valve seals,,,,,
Old Jul 6, 2003 | 11:28 PM
IrocZonNos's Avatar
How difficult would it be to replace the valve seals. Would it be beneficial to replace the heads?
Old Jul 7, 2003 | 07:07 AM
DJP87Z28's Avatar
Not necessary to replace the Heads for the installation of Valve seals. Depends on your mechanical skills to replace them and it may not be your DIY type of job.
Old Jul 7, 2003 | 07:11 AM
Guest
Guest
Posts: n/a
if you can remove the hands and put the car back toghert and it still runs you can replace vavle seals. :-D
Old Jul 7, 2003 | 08:54 AM
Metaldrgn's Avatar
Originally posted by DJP87Z28
Valve seals,,,,,
Could be the piston rings going too.
Old Jul 7, 2003 | 08:56 AM
Metaldrgn's Avatar
If you've never done it before, it'll probably take about a month to do it so if you work I hope you have another car.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
