engine sits to high
Old Jul 14, 2003 | 02:45 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
engine sits to high
I used an engine out of a mid 80's blazer and the mechanical fan is sits to high along with the altenator braket and air cleaner. this is beginning to drive me nuts. What did I do wrong
Old Jul 14, 2003 | 03:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you used the wrong clamshell brackets on the motor. You used the truck ones instead of your car ones. Should be an easy fix.
Old Jul 14, 2003 | 04:33 PM
Car: 89 camaro RS
you mean the mount anchors or the brackets that hold the anchors. the anchors are for a v-8 camaro. If I need the brackets what is the part number
Old Jul 14, 2003 | 04:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I mean the piece that bolts to the block, as opposed to the piece that sits on the frame
Blocks are all the same
Old Jul 14, 2003 | 04:43 PM
Car: 89 camaro RS
will the v-6 brackets work
Old Jul 14, 2003 | 04:48 PM
Car: 89 camaro RS
will the brackets off any car mounted blocks work.
Old Jul 14, 2003 | 10:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Any "car sbc" mounts may work, but don't take any chances. Just find a set from a Firebird or Camaro that had a V8 in it.
Old Jul 15, 2003 | 06:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get the right ones, then you won't have this problem any more. Get some other ones, who knows?
6-cylinder ones are different.
Go to the dealer if you have to.
Old Jul 15, 2003 | 10:46 AM
Car: 89 camaro RS
thanks guys
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
