1988 5.7 Camaro IROC
Old Aug 9, 2003 | 10:26 PM
howlingwolf's Avatar
I am thinking of buying a 1988 Camaro IROC 5.7 auto,.It had a blown engine due to over heating,..The engine has been swaped from another Camaro IROC 5.7 that had been in a accident,. and this newer engine has 40,000km on it and the car has 160,000km,,..My concern is..I'm not really sure if the engine is out of another IROC,.and if it isn't does it matter?...I was told the car is all stock except for the engine swap,..I was hoping that is was all orignal,..and all matching numbers,..My questions is,.Is this Camaro still an IROC after it's had an engine swap?,..and can it be replaced with any 5.7L or 5.0L,..to make a quick sale?
Old Aug 9, 2003 | 10:45 PM
84 Challenge's Avatar
That car will always be an Iroc, even if someone put an Iron Duke 4-cyl in there. Just as long as someone replaced the blown engine with something comparable or better and in comparable or better condition, than I wouldn't worry about it. Just make sure it's a 350. How do you know the new motor is from another Iroc? Are you keeping this car stock? If not, just make sure it's a 350 and mod away, don't worry about it! One more thing...does it run and drive good?
Brandon
Old Aug 9, 2003 | 11:35 PM
When I first went and seen this car,.The owners gave me the keys to start it up,..I just turned the keys she fired right up,.I let it idle for abit and she idle beautiful,..me and the owner went for a ride there was no hesitation,..he told me to punch it,..it was very responsive ,.and yes I would like to keep this car stock,.. I was concerned,..because of the engine swap,..I didn't really know what kind of engine was in it.,..I'm not sure if it's the engine is from a IROC or not,.but can it be a 305 from another Camaro ,.just leave the TPI and Injectors on the replaced engine?
Old Aug 10, 2003 | 12:54 AM
BrianI's Avatar
Could be a 305. Could also be a non roller cam block as well. Hard to say. If you plan on keeping it stock, I don't guess it would really matter anyway.
Old Aug 10, 2003 | 12:50 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You could always check the casting numbers on the block. Or even run the VIN attached to the engine.
Old Aug 10, 2003 | 01:10 PM
Well I have an udate on whats in the 88' iroc,..it is an 350 from a chevy p/u with low kms,...so Its not an iroc engine after all...any suggestion on if I should keep the p/u engine in and drive awhile till I have enough for a high performance engine,..I live in Canada ,..and wondering what would be a good replacement engine for this car.
Old Aug 10, 2003 | 04:02 PM
You don't need a new engine. Just get a 383 stroker kit, new intake, carb, heads, headers and you're all set. Did I miss anything guys?
Brandon
Old Aug 10, 2003 | 06:25 PM
Thanks for all the replys,...I spoke with the owner and I'm going to buy the Iroc
Old Aug 10, 2003 | 10:51 PM
Good luck with it!
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
