alternator bracket problems
Old Oct 2, 2003 | 03:08 AM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
hey i was wanting to know if anyone else has had the same problem as me...ok i have early 462 camel hump heads and i am running nothing in the line of accesories, just water pump and alternator and i was wondering if any sort of alternator bracket is made to mount the alternator low (as it is the only place to put it) that works with the long water pump
thanks
Old Oct 2, 2003 | 05:38 AM
ede's Avatar
ede
moroso makes a crank pulley set up and low left side alternator bracket. take a bucket with you to carry the jack in, they're kind of pricey. i think mine ran well over 200 dollars.
Old Oct 3, 2003 | 03:39 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I don't know if iit will clear the hood (I don't see why it wouldn't) but summit or jegs sells a cheapie bracket for like $12 that mounts onto the block and puts the alternator high (like where the AC condenser is). It is really just a stick with a bolt hole but I know ppl that have run 'em for years and neverhad a problem.
Old Oct 3, 2003 | 01:18 PM
1989RS's Avatar
thats great but...if it has to be mounted in the heads, then i am screwed...462's do not have accessory holes in then, nor any spot to drill/tap thanks,john
Old Oct 3, 2003 | 03:07 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
nah it mounts to the front of the block.
Go to summit and check it out.
Old Oct 3, 2003 | 05:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not just check out ebay or something for some pre-1969 brackets? They usually bolt to the water pump, not the heads.
Old Oct 3, 2003 | 06:21 PM
1989RS's Avatar
i thought about that.... the pre 69 brackets throw belts, they flex too much, or so i am told
thanks, john
p.s. what is the p.n. on that summit piece, thanks, again
Old Oct 3, 2003 | 10:24 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
http://www.jegs.com/cgi-bin/ncommerc...23&prmenbr=361
style C. Sumit used to have 'em too but I can't find it on their site.
Old Oct 4, 2003 | 03:15 AM
1989RS's Avatar
thanks, that will prolly help loads, but if not, off to the shop to make something myself..... i will look into those brackets
Old Oct 7, 2003 | 05:45 PM
Air_Adam's Avatar
If you are good with tools, you could just make your own brackets with some heavy metal... like maybe 3/16" thick steel?
My cousin did a similar thing a couple times... he made some brackets for the tail lights and the rear licence plate on his '52 Ford and they look almost aftermarket they are so good. It was 3/16" thick steel IIRC.
He also made me and EGR block off plate out of aluminum, for my 4bbl manifold.
Far as I know, all he used to make them was a Dremel tool, a hacksaw and a file, and I guess a drill too for the bolt holes.
It really doesn't seem to be too hard, but I haven't tried it much myself.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Nov 11, 2015 10:46 PM
db057
Sep 4, 2015 07:57 AM
Dialed_In
Aug 20, 2015 01:45 PM
