V6 to V8 Swap
Old Oct 11, 2003 | 09:02 PM
Rump132's Avatar
V6 to V8 Swap
I pulled the old 2.8 V6 out of my '89 Camaro and dropped in a 4bbl 305. Everything has gone smoothly so far and I am about to tackle the wiring changes. I was wondering if anyone had any help or suggestions to get me started on this part of my project. I have never tried anything this extensive and though I am sure I will finish it I would sure like some guidance as far as what needs to be done to finish this swap. I basically have the wiring and hoses to finish and then I should be about ready to fire her up!
Old Oct 12, 2003 | 01:39 AM
cdartz's Avatar
Sorry, my swaps were to TPI so I can't help you. Also, I think you need to post some more info so hopefully someone will be able to help. ie: what wiring harnesses do you have to work with.
Old Oct 12, 2003 | 05:40 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
get a chilton book (or better yet a factory service manual if you can afford)
answered all my ??? when i did my swap
Old Oct 14, 2003 | 12:32 PM
Guest
Guest
Posts: n/a
Re: V6 to V8 Swap
if your going non- computer controled your goign to need to get the lock up in the trans to work, speed do, and some small **** here and there..
Old Oct 14, 2003 | 08:10 PM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
I did the swap with the bare minimum.No p/s swapped in a s10
steering box,one wire alternator,mechanical guages,v8 radiator with aftermarket dual electric fans.Aservice manual will give you the wiring setup.I pulled the computer wire harness ,just have
the main wire harness .You need one 12 volt keyed power source for your HEI Distributor .There is alot of other little stuff,but if you do a search you will find most of what you need to know.
Old Oct 22, 2003 | 11:30 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
You could throw a tarp over it and park it under a tree, OR maybe buy a minivan..oops, you already have one!! LOL
Old Oct 23, 2003 | 10:25 AM
vipess's Avatar
i have a freind who did something similar. because you went to a carb you're gonna run into problems with basicaly all you're wiring. i'm talking even the wires to you're brake lights and everything. you basicaly need a new wiring harness....unless you can splice that stuff you're self.
but because everything was computer controlled before and now its not gonna be you'll find it a little harder to get all you're gauges and stuff hooked up too.
Old Oct 23, 2003 | 05:34 PM
sooooooooooooooo much misiformation right there
Old Oct 23, 2003 | 05:53 PM
Guest
Guest
Posts: n/a
LoL look at home many Post he has... what more do i need to say LoL don't be on the motor swap board unless you have done the swap your self... the ECM doesn't run the brake lights LoL
Old Oct 23, 2003 | 06:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You will need a power wire to the distributor, a tach wire from the coil, oil pressure gage, coolant temp gage (driver's side head), alternator wiring, and switched power to the electric choke, assuming you have one. Not sure if your radiator fan(s?) is ECM controlled or not - if so, you'll need to rig up a temp switch (passenger side head) and relay.
Most if not all of the wiring you need is already in the harness. Most if not all of what you don't need can be easily separated and removed without cutting any wires.
Old Oct 29, 2003 | 09:48 PM
Rump132's Avatar
Thank you all for your advice. I was already heading down the same lane, it just helps to have some people that are experienced back up what I was thinking.
Old Oct 29, 2003 | 10:23 PM
vipess's Avatar
ok, so i havn't posted that much any more, guess that means i don't know what i'm talking 'bout then...
you're telling me that you did a swap from a fuel injected to a carb and you didn't have to swap out wirring for you're lights...
Old Oct 29, 2003 | 11:33 PM
Guest
Guest
Posts: n/a
yes.
the ONLY time you have to worry about the wireing for your lights when you ditch the FI is when you have the digi. dash
Old Oct 30, 2003 | 12:04 AM
vipess's Avatar
even when swaping in an older engine...don't think so. the tail lights are different from different years (but you already knew that). the wiring isn't the same.
Old Oct 30, 2003 | 12:30 AM
Guest
Guest
Posts: n/a
in all 3rd gens what do not have the digi dash you will never have to worry about your tail lights when you deleted the computer they are all ran off relays and switches not from the ECM
Old Oct 31, 2003 | 11:51 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
oops, double post. :lala:
Old Oct 31, 2003 | 11:54 AM
9D1BURD's Avatar
Car: 1997 Z28
We already know you are clueless, isn't that enough.
As far as i know, the brake lights work off a switch under the dash.
There is a metal plate holding the switch, when the pedal is not being pressed, it is holding the switch closed.
When you press the pedal down(or away from the metal plate, it activates the switch, and holy hell, its a mircale, the brake lights work.
Old Oct 31, 2003 | 12:07 PM
Guest
Guest
Posts: n/a
9D1BURD has seen my swap in person and knows how clean the swap was so i kinda knwo what i'm talkign about.
we don't like it when people give BS info on this board.
Old Nov 16, 2003 | 06:33 PM
Guest
Guest
Posts: n/a
opps sorry
Old Nov 17, 2003 | 01:14 PM
did he have to change his muffler bearings too?
Old Dec 3, 2003 | 12:19 AM
Rump132's Avatar
Finished the wiring
Just thought I would post an update. I finished the wiring. I tore out the ECm and all the wiring harness that was attatched to it. I then connected the half dozen wires remaining and fired her up. The first thing I noticed when I reattatched the battery was that the hood light came on. That was a good sign. Then, when I opened the door, the interior lights came on. Guess what happened when I tried a turn signal and the brakes? They all came on. Big suprise. Sorry to start such a big argument here but thanks to those of you who responded with the usefull information. I had the diagrams out of the books and posted here, it just helps to get a little advice from those who know first hand. Thanks!
Old Dec 3, 2003 | 09:16 AM
pskel350's Avatar
Im glad the swap worked out for you!
The wiring for my swap went easy, just a little common sense, and a diagram or two, and everything works out just fine.
Goodjob on the swap, you wont be disappointed
Old Dec 14, 2003 | 11:57 AM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
why would you even touch the wiring goin to the lighting? i'm really stumped about that..........like someone else stated tach, dist., starter and alt. is all that you need to mess with...........the old computer harness is now obsolete in a carb conversion so you can discard that..........
Old Dec 19, 2003 | 03:54 AM
dennis6's Avatar
Car: 1991 Camaro RS
On my 91 RS 305 TBI the hood light wire runs with the computer harness into the fender. I cut most of those wires. Also there was a center harness coming out of the firewall and a harness coming out of the driverside firewall. THey were all connected. The only thing I regret is having to track down what the tranny and fuel pump wires were. OOPS
Old Dec 22, 2003 | 02:49 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
even when swaping in an older engine...don't think so. the tail lights are different from different years (but you already knew that). the wiring isn't the same. I think we need an idiot test for new people before they post to keep the wrong information from being posted just from this last week i counted four new people posting wrong information.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
