GTA engine swap
Old Oct 25, 2003 | 07:49 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
GTA engine swap
How hard should it be to swap an engine out of on a 91 GTA? I have never done an engine swap before, but we are goin to tackle it here soon.
Old Oct 25, 2003 | 08:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you mean you're going from TBI 305 to TPI 350.
Not too bad. Take pictures of both before you start. Tag/label things as you disconnect them. Take out the harness in one piece, you don't need to cut anything. I left sensors that weren't attached to the engine on the harness as I disassembled.
Worst part will probably be dropping the tank to change out the fuel pump. An alternative would be to put in an in-line electric and let the TBI pump be a pusher.
Old Oct 29, 2003 | 01:14 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
No, its got a tpi engine in it but it slung a rod, so we are going to replace it with a 350.
Old Oct 29, 2003 | 07:55 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
As five7kid stated, definitely take pictures prior to removing the old engine as a reference to where items connect. A good advice would be to start putting some of the accessories from the old engine to the new one. As far as TPI goes, the only problem I had was making sure I had the right bolts going to the plenum and so on. Since going with a 350, you need to change the 305-knock sensor to that of a 350. Chip will need to be replaced and fuel pump. Question, since you already have a cat-back system, why not invest on set of headers? Hope I’ve help and best wishes on your engine swap.
Old Oct 30, 2003 | 02:30 PM
Steve89GTA's Avatar
The fuel pump is the same between 305's and 350 TPI's
Old Oct 30, 2003 | 07:45 PM
five7kid's Avatar
Ok, I get the part about a '91 GTA having a TPI.
What I don't get is what car is getting an engine. In your sig, you say you have an RS with open element, etc. In the message text, you talk about a '91 GTA.
Are you saying you are helping someone change the engine in their '91 GTA? If so, that typically isn't called an engine "swap", but a replacement. Going from a 305 to a 350 isn't really a "swap", either, since the basics are all the same.
However, the factory used different injectors, fuel pressure regulator, knock sensor, & PROM for 350s than they used for 305s. If you want to call that "swap" stuff, I suppose you could make that arguement. More like "tuning" I'd say.
But, I think I now understand that you're going to change out an engine in a '91 GTA. Am I getting closer?
Did you really want to know how hard it is to change out an engine????
Old Nov 6, 2003 | 07:34 AM
kentucky's Avatar
Help
I have a 1988 firebird that had a 350 5.7 tune port from a 1989 formula firebird. the engine is dead and gone , i found a low milage 305 tune port from a 1988 or 1989 firebird. I need to know if my wireing harness will work on the 305 tune port. i know that i would have to change the eprom , i have a chip from a 89 firebird that had the 305 in it . i know that the computers are the same. BUT I NEED TO KNOW AOBUT THE WIreing HARNESS .I ALSO know that the fuel pump is the same..email me an answer someone please cescomputers@adelphia.net
Old Nov 6, 2003 | 12:15 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
my 305 had rod knock so all I need is an L98. LB9 to L98 seems like the way to go just because all the accesories still work.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
