what's the biggest engine made?
Old Oct 31, 2003 | 07:34 AM
anubiscougar's Avatar
Ok... i always thought a BB 632 was the biggest engine made... Now i just saw a 644..?? wtfreak..
http://www.cars-on-line.com/90gmc8976.html
So... is that real? or did they just do it like you do w/ 383 strokers, take a 350 and put a 383 stroker kit in it?
Or is that real? they make 702's or something? lol.
dang... if i was a rich man.
Old Oct 31, 2003 | 10:05 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
define engine....
because i can show you a engine with a 12 foot stroke, and a bore large enough for you to live in.
Old Oct 31, 2003 | 12:47 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
What about the sun?
That baby makes some power.
I'm such a b!tch.
Old Oct 31, 2003 | 12:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i know hes atleast limiting it to piston 4 stroke internal combustion engines swerve driver
Old Oct 31, 2003 | 12:52 PM
Car: 1991 RS
Ohhhh.......
That narrows things down some.
Seriously the 632 ci was the largest Chevy I had heard of.
If we're talking largest in terms of cubic inches, gas, 4 stroke, internal combustion, any make or brand- I'll see what I can ddig up.
S-D
I have to apologize for calling myself a B!tch. Sorry!.
Old Oct 31, 2003 | 12:54 PM
Car: 1991 RS
This one is diesel, but it is pretty huge.
http://www.k4viz.com/12-Cylinder.html
S-D
Old Oct 31, 2003 | 05:42 PM
meaning, fit in a car engine, rofl... i've seen 8 cylinder engines larger than a warehouse... you know what i mean.
infact, that was the engine.... *sigh*.
my friend told me 644 is the biggest. *shruggs*
Old Oct 31, 2003 | 08:43 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Here's a 706 made by Scott Shafiroff.
MCM
Old Oct 31, 2003 | 08:46 PM
Car: '82 Trans Am
Transmission: TH475
And a 762 by Sonny's.
Old Oct 31, 2003 | 09:05 PM
oh my gosh....
Old Oct 31, 2003 | 09:09 PM
ok... i know with 350's.. it's the parts that you put in it, to make it a "383 stroker"...
so is that what they do with the 632's to make them 706's and 762's as well?
But... what really do the parts do.. just the length of the piston arm and.. a few other things.. i've been told..
Old Oct 31, 2003 | 09:34 PM
kingnothing23's Avatar
Car: 1988 chevy camaro sport coupe
Engine: V6 2.8 173
Transmission: 5-speed
I think I got you all beat. I asked a good friend about a drag strip in hattiesburg and he told me about this car there. He said it is a early 60's nova and has a 800 cu in engine with tunnel ram with(2) 4's and 3 stages of nitruos. The car is supposed to run 7's and be street legal at that!! I havent seen that car yet, but I plan on going to this track and trying to get some pics of it if I can.
Old Oct 31, 2003 | 09:39 PM
mmm
Old Nov 1, 2003 | 03:28 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
As far as "normal" automotive engines go some where over 800ci. When you start getting into diesels and avation engines things get larger...
Old Nov 1, 2003 | 07:14 AM
have a link to an 800? possibly..?
Old Nov 1, 2003 | 10:48 AM
Engine: V6 2.8 173
I have no pics of this 800 cu in engine or this car. I havent been to this drag strip to see this car run yet, but my friend said he talked to the guy when he went there.
I always take pictures of engines and cars that I havent seen before so when i do get a pic of this car I'll post it
Old Nov 1, 2003 | 01:39 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
World products motown blocks with a tall deck, razed cam bore, and small base circle cam can suppot a 5.850" stroke on a 4.625 in bore. If I did the math right that is 786 ci.
Old Nov 17, 2003 | 08:13 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
It's Donovan
Donovan makes the 700 and 800cid big block.
http://www.donovanengineering.com/B...00BigBlock.html
There could be others making larger engines, but not as far as I know at the moment.
Actually it seems that sonny's have an engine at 812 ci..
Old Nov 17, 2003 | 08:28 PM
tilstad's Avatar
Here's a picture I found on Sonny's first page on their website.
You could always innstall it in a thirdgen, perhaps put on a little smaller carb and drive it on the street..
It seems that thair biggest engines are all Donovan blocks.. guess engine size is limited to the blocks, and since there isn't that many manufacturers of engine blocks, it will not be any larger than the ones that they currently make.
Old Nov 18, 2003 | 07:46 AM
bigals87z28's Avatar
Car: Check The Sig
ha ha i win... 904 CI... booo ya!
DOHC moat motor.. makes like 2500hp..something insane like that... forgot.
edit.. here is the info from the web site..
The old saying, “there’s no substitute for cubic inches”, abundantly applies to the new “SCHUBECK 904” cubic inch, injected engine. This four cam and four valve per cylinder, naturally aspirated V8 power house will delivers 1200 ft. lbs. of torque on pump gasoline without complicated, noisy and cumbersome superchargers.
The engine incorporates a closed cooling system featuring a heat exchanger and utilizes both fresh and sea water pumps. The engine also features a four stage, dry sump, oil system, a power steering pump and alternator. The engine also supports the latest Accel/DFI Gen 7 electronic fuel injection system.
Attached Thumbnails what's the biggest engine made?-904-monster-dohc-boat
Old Nov 18, 2003 | 05:14 PM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
I have seen in a magazine 55 chevy with 1650cid v12 engine from p51 mustang ww2 fighter plane. Or should i say 1650 engine with a chevy, check out you self:
http://www.cardomain.com/memberpage/314824
Old Nov 18, 2003 | 05:36 PM
tilstad's Avatar
Since that 1600ci engine really isn't a car engine, and really don't fit a car at all, I would say that the 904 is the biggest car engine one can get.
The cadillac sixteen V16 engine is about 835ci..
Old Nov 24, 2003 | 11:05 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
this post is retarded
Old Nov 28, 2003 | 02:20 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
The Space Shuttle 81,000,000 hp. With solid rocket boosters. But the mileage will kill your wallet.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
