will it work????
Old Dec 17, 2003 | 02:16 AM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
will it work????
i got a carberated 355 im putting in a 89 rs could i use the stock electric pump ran thought a regulater then to the carb and get good pressure???OR sould i take out the rearend (for the 3rd time this month)drop the tank take out the pump and run the mechanical pump???
How would i hold the fuel line in the tank if i wanted to run the mechanical pump?? i built this motor to be sprayed a least a 225 shot and more.
i heard that if you run the stock electric pump to a regulater and upped the psi you can with stand big hp of spray like this on a carb.
Would i still need the t.b.i. computer to do this???
uuurrrrrr so many questoins so little time.
any info will be very helpful serriouslly!!! thank you
Old Dec 17, 2003 | 09:08 AM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
As long as you use a regulator and get it down around 6-7psi you should be fine with your stock pump. Also, you don't need to keep your ecm, just keep the fuel pump relay and it will be fine.
Old Dec 17, 2003 | 09:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use a regulator that includes a return port. Dead-heading the in-tank isn't a good idea (will overheat).
Old Dec 18, 2003 | 01:07 AM
rustbird's Avatar
Car: 92 firebird
Ok im thinking on the right track then just getting nervous lol
thanks alot guys
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
