pics of motor mounts or which holes
Old Feb 21, 2004 | 12:33 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
any1 have any pics of their motor mounts. being the beginner i am i think i mightve mounted it to the wrong holes
being mountted to the wrong holes i have a gap between the spline of the transmission and the driveshaft
Old Feb 21, 2004 | 02:28 PM
MCas7's Avatar
What motor did you swap out? If you swapped from a V6 to a V8 then the motor mounts should be mounted in the forward holes. Did you swap transmissions too? Did you go to a different type of transmission?
Old Feb 24, 2004 | 01:23 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
i did swap transmissions. there was a 700r4 for the 2.8 v6 in there before and now it is a v8 700r4. same transmission i hope?
Old Feb 24, 2004 | 03:11 PM
TexasLT1's Avatar
Car: '92 RS
Re: pics of motor mounts or which holes
How much of a gap are you talking about and where exactly is the gap at? There shouldn't be that much of a difference between mounting positions
Old Feb 24, 2004 | 09:17 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
its about an inch or inch and a half between the where the driveshaft used to be and where it hooks up to the transmisson. (i can tell its a new gap because my driveshaft is rusty and there is no rust where this gap is if u get wut im trying to say).
Old Feb 25, 2004 | 07:01 AM
MCas7's Avatar
As far as length goes, there is no difference between the 2 transmissions. The only difference is the shape of the bell housing. The V6 bell housing is much narrower than the V8. It sounds like you are talking about the yoke which slips into the back of the transmission. It is really hard to know exactly without seeing a picture or something.
Old Feb 25, 2004 | 10:36 AM
cammy's Avatar
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
im in the midts of changing from a v-6 to a v-8 when i get in the shop ill take a pic and circule the holes the motor should be mounted on for the motor mounts but if thay were on the v-6 holes i would like to know how you managed to fit the motor on their because that's what i tryed
im not 100% for sure if the holes im looking at are the right ones but at least some one els could re-edit the picture to circule the right holes
Old Feb 25, 2004 | 10:41 AM
PhilM's Avatar
Car: Accepting applications...
will this help?
Old Feb 25, 2004 | 01:19 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
yes that did help i have the mounts in the right place and my motor is in right, BUT my driveshaft is still too small for some reason.....ill triple check
Old Feb 25, 2004 | 01:20 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
do those mounts work? theres no rubber.......
Old Feb 25, 2004 | 01:47 PM
PhilM's Avatar
no rubber because they are solid mounts
Old Feb 25, 2004 | 01:50 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
didnt no
i guess u learn new things everyday
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
