'89 Pontiac 350 TPI to Chevy trans?
Car: Jeep Cj7
Engine: TPI 350 (soon)
Will a 1989 Pontiac GTA TPI 350 bolt to a Chevy trans??
Am doing swap into Jeep. Have bigger, badder, built Pontiac 350 TPI for free. Is it possible to bolt up, or do I have to have a BOP trans?
thank you
thank you
In the third gen camaros and firebirds the same engines were used and therefore used the same bellhousing bolts and actually everything is the same. It is not like in the 60s and 70s when there were chevy and pontiac engines and everything was different on them. Yes, you can use it, it will bolt right up.
Sanjay
Aug 12, 2015 03:41 PM
