Lt-1 95
Old Mar 8, 2004 | 01:28 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
Lt-1 95
better stock with lt1 intake or stock and carbed? and when injection is better than carb and when carb is better than injection?
Old Mar 8, 2004 | 03:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Lt-1 95
Leave it FI. The induction set-up on the LT1 is plenty to feed that motor. You will lose all the advatanges of a multi port set-up if you go the carb route.
Old Mar 8, 2004 | 07:40 PM
TexasLT1's Avatar
Car: '92 RS
Re: Re: Lt-1 95
If you want a carb, get a traditional SBC. It's completely pointless to get an LT1, rip off the fuel injection system that you paid so much for, then reduce the potential of the engine by slapping a carb on it.
Old Mar 8, 2004 | 11:23 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
yeah, leave the FI, it's freakin awesome!
Old Mar 9, 2004 | 04:10 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Oh yes, dont FUBAR a very nice thing...the only down fall in the whole system is the Opti But the 95 has the up graded opti..vented with vaccuum.. a lot longer life.
Old Mar 9, 2004 | 03:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed... if you want a carb'd motor, go get a junkyard 350. That will be cheaper to build than an LT1 anyway.
Old Mar 9, 2004 | 04:11 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
the LT1 with fuel injection is like THE FORCE! USE THE FORCE! We'll help you get it done, don't worry about all the wiring and whatever. get as much of the harness as possible. I had an entire buick station wagon harness but that was a little excessive. Label everything! evenif you don't use it, label the connector anyway it will help
Old Mar 9, 2004 | 10:58 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I think he is asking if he should put an Lt1 intake on the engine he already has. And also, when is fuel injection better than carb and vice-versa.
Sorry...can't help with the Lt1 intake on your current setup but someone on here will probably chime in.
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
cRoe4
Aug 7, 2015 08:46 PM
BlazinOR
Nov 23, 2001 08:32 PM
elevario
Jun 16, 2001 11:37 AM
