do i need new motor mounts??
Old Mar 29, 2004 | 05:22 AM
junkie's Avatar
Car: 84 camaro berlinetta
im sure you all have been asked a million times but here goes a million and 1 im doing a swap from a 2.8 v6 with a t5 to a 305 with a 700r4 tranny do i need new motor mounts or can i just move the mounts from the 2.8????
Old Mar 29, 2004 | 09:12 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: do i need new motor mounts??
You need new motor mounts and I think they ahve to be reposisitoned as well. Check out the V6 board for that.
Old Mar 29, 2004 | 11:53 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Mounts from the 2.8 cannot be used, they are very different. You can buy new v8 rubber mounts for 20 dollars for both sides at your local parts store (I got mine from autozone for $20). You will need to move your motor mounts all the way to the front, the v6 are towards the back and you will need to bend your brake line.
Old Mar 29, 2004 | 07:13 PM
junkie's Avatar
thanks for the help...
Old Mar 29, 2004 | 08:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may be able to use the chassis half from the V6 for the V8 (same concept, same shape, different set of bolt holes as mentioned above), but the engine half without a doubt is different.
Perfect time for poly mounts. Wish I had done that.
Old Apr 4, 2004 | 11:08 AM
junkie's Avatar
how did you get the mounts out??? mine are nut and bolt and im having a hell of a time getting to the nuts is there some kind of trick to it?? it really sux cause the v8 had to be put in place so now i have to do it wit the engine in there doh!!!
Old Apr 4, 2004 | 02:34 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
how i got my bolts in that litte S***** hole is i took a swivel socket and put some wheel bearing grease on it and played around with it untill it caught on. Then i took a crows foot and a 3/8 air ratched and tightend it.
Or you can just drop the front control arms and it would be a piece of cake. thats what i would do now thinking about it. You have to replace the springs anyway.
Old Apr 4, 2004 | 03:44 PM
junkie's Avatar
my springs didnt drop at all my camaro still sits stupidly high but your saying i should be able to get it with a swivel..thats all good i can live with that=) and do you know if i have to get a new crossmember for the tranny???
thanks
Old Apr 4, 2004 | 03:55 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
when i did my swap i tried the v6 one but it didnt work. I used one from my donnor 1989 camaro. So you most likely will need a new crossmember
Oh by the way the v6 tranny will not bolt up to a v8 because the bell housing is smaller
Old Apr 4, 2004 | 04:05 PM
ljnowell's Avatar
When you go to do those mounts, I used a 15mm socket on a 3/8 univeral with about 10 inches of extension. Worked like a charm on the top two. for the bottom one, i jsut bent a 15mm wrench with a torch and a vise and put uit through the bottom to get on it.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
