motor mounts
Old Apr 30, 2004 | 06:52 AM
junkie's Avatar
Car: 84 camaro berlinetta
motor mounts
ok ihad a hell of a time getting the mounts off now im thinkin for the new mounts if i were to thread the frame holes would that be good enough to hold everything down??just trying to avoid that insane nut on the mount ...and has anyone here ever used the original edelbrock torker intake???..if so what did you think of it???and if things keep goin the way are so far i swear im just gonna buy a new camaro..dag nabit..lol..my advice for anyone looking to do the v6 to v8 swap..dont do it just buy a v8 car itll be cheaper..
Old Apr 30, 2004 | 07:57 AM
PhilM's Avatar
Car: Accepting applications...
threading the frame might not be a great idea, it isn't that thick after all so there won't be many threads. many people will get the inner nut tack welded to the frame, but if you are only doing it one time might as well fight it out and put the nuts back on. many of us have changed them without droppin the a-arms.
Old Apr 30, 2004 | 08:22 AM
TexasLT1's Avatar
Car: '92 RS
Dropping the a-arms is by far the easiest way to get to the mounts. Put a jack under the a-arm, take out the two pivot point bolts, drop the arm down and pull the spring out. All the room you need to get to the bolts holding the mounts on.
Old Apr 30, 2004 | 11:41 AM
ljnowell's Avatar
If you have two people it doesnt take that long. I can tell you from personal experience that they go on a lot easier than they come off. If you use a 15mm wrench on the bottom one on each side it works like a charm, but there is a catch. Heat up the boxed end of the wrench, and bend it so that when you stick it into the frame, it sits flat against where the bolt goes. If you use a swivel and a 15mm socket for the top ones with a bout 15 inches of extension, they will be on in less than 1/2 an hour. Considerably easier than selling your car and buying a v8 one. But that does seem to be the consensus on this board. Seems to me like most people here probably never owned a car older than a third gen, or have worked on stuff very much.
Old Apr 30, 2004 | 12:10 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I think selling your car instead of doing motor mounts is stupid. v6 to v8 really has nothing to do with it. What if you already had a v8 and the mounts went bad, you'd still be in the same boat your in now. Would you sell your car because the motor mounts went bad? Of course not. Problem with these cars is the are not the easiest to work on. But then again they are not the hardest either.
Old Apr 30, 2004 | 12:14 PM
ljnowell's Avatar
Thank you very much. Its about time some one else said it too. There was a thread a while back where someone threw a fit that he couldnt change his sparkplugs, and it was a pain to do anything on HIS car so he was going to get rid of the POS. All I could think was, man, there are how many of us who deal with that on a daily basis. What a whiner. Course, junkie, I'm not knowcking you, dont think that. I converted my v6 to a v8, and there were definately times while we were working that I was thinking, Man, why didnt i just buy a V8 car? But, it was my car, and I like it.
Old Apr 30, 2004 | 12:53 PM
br()bert's Avatar
Car: 85 firebird
Ill be their soon, i bought a v8 motor with trans, its a tpi motor but i might convert it to carb. My car has the crappy 2.8 in it now, so soon ill be dealing with the mounts.
Wouldnt it be easier to drill out the old bolt? In my case im not gonna reuse anything from the old mount anyway.
Old Apr 30, 2004 | 12:59 PM
ljnowell's Avatar
Really, if you take a cheap wrench and look at the angle it needs to be bent to, and do it that way, and use the swivel and extensions, then have someone else get the bolts from the top with an impact, they can be changed in an hour. no problem. Took me about 1hr45mins, but we had to go to the partstore, and figure out to bend the wrench.
Old May 3, 2004 | 05:04 AM
junkie's Avatar
thanks for the info ..ya theres a few reasons im getting edgy about the whole thing i think the biggest one is the fact im in a building parking lot people get all pissy when you work on your ride and than the fact that i need just about everything rad exhaust suspension auto shifter assembly all linkage, switched from a t5 ,im not ready to give up yet ..but damn itll suck if i gota miss the summer i hate drivin the family cruiser..lol
Old May 3, 2004 | 05:07 AM
junkie's Avatar
ya i looked into it more ..bad idea itll rip out i keep gettin told..thanks though
Old May 3, 2004 | 05:24 AM
junkie's Avatar
just about every car ive owned has been a camaro this is my 3rd 3rd gen and ive had a few 2nd gens too wish i had of kept those ..I always do the work myself ill do everything but trannny work ..but it is first time ive done mounts well motor mounts anyways like this if i didnt have to rush id be done but having the motor just sitting there in the way of the mounts i might ad makes it a pain i have to lift the car so i fit under and lift the tranny cause thats not bolted up yet either and lift the motor so i can get to the mounts i only have so many jacks and stands..lol
Old May 3, 2004 | 05:32 AM
junkie's Avatar
never said i was gonna sell it just said id prob just buy a v8 camaro ..than i could take my sweet time doin it guess i should of put all the things goin on with it right now..theres alot more than just the mounts the car is pretty much gutted as well but thats for the other topics
Old May 4, 2004 | 01:39 PM
ljnowell's Avatar
I like that, sounds exactly like me. I'll take on anything that gets in my way, except a transmission.
Old May 5, 2004 | 04:17 AM
junkie's Avatar
so do you have the edelbrok torker 2 intake??? how do you like it ?? i got the original torker intake on its way got it cheap it needs some fixin just wonderin how your likein it .
Old May 5, 2004 | 08:13 AM
ljnowell's Avatar
A lot of people talk a lot of trash on it, its a pretty good intake. No its not a victor Jr, but it also costs less than 1/2 a victor Jr. Bottom line is, it runs good, and gets great upper RPM power. Its a good intake.
Old May 6, 2004 | 04:34 PM
junkie's Avatar
ya i got my torker for 30 bucks so if its better than stock its all good
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
