LT1 Swap, Power Steering Hoses/Resovoir
Old May 5, 2004 | 08:54 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I hav AC on my car, and I am loking for a place to mount the PS Resovoir.. From what I've found, everyone doesn't have AC and thus there is a perfect spot to mount it on the pass strut tower..
Also, what are we using for a PS hose? Is there anything that bolts up? Or should I just buy a 96 PS hose and get it spliced on to my 89 hose?
Old May 5, 2004 | 09:30 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm interested in the same question. I'm going to keep my A/C too, and this is a question I've been asking myself too. Anyone?
Old May 5, 2004 | 11:58 PM
TexasLT1's Avatar
Car: '92 RS
This is how 6speedIROC mounted his reservoir.
Here is how I mounted mine and how I originally mounted the PCM. It has since been moved to the top of the intake.
Notice I have functioning A/C.
Old May 6, 2004 | 12:01 AM
TexasLT1's Avatar
Car: '92 RS
Re: LT1 Swap, Power Steering Hoses/Resovoir
The B-Body (Caprice/Impalla) hose is a near perfect fit. Might need a little bending to connect to the steering box. For the return line, I used part of the original hard line with rubber hose on the end connecting to the reservoir.
Old May 6, 2004 | 07:35 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I forgot to mention it is an fbody acc bracket
Old May 6, 2004 | 07:36 AM
TexasLT1's Avatar
Car: '92 RS
So are both of the ones in the photos.
Old May 6, 2004 | 07:43 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
any particular yr b body? i checked and noone has a hose, so i'll have to order, or go to junk yard.. 95 for eg, be ok?
or the alternative is to get a 94-97 f body hose and get it spliced into my 89 hose
Old May 6, 2004 | 08:22 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
noone with in 100km has either a b or f body hose.. grrr... anyone know if a gas line fitting will work? They are nearly the same, I could get my 89 hose extended with the gas line fitting bent up and crimped on.
Old May 7, 2004 | 02:57 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Here is how I mounted mine, for the power steering return line I used a 5/8" 5 1/2 foot heater hose and just put some hose clamps. I used the stock steering box return line and just cut it with a hacksaw to remove the slack since I mounted the reservoir very close to the steering box using a 3.8 v6 98 f-body reservoir and mount. I used a steel braided line and russel power steering fittings, 1 16mm fitting for the power steering pump and a 11/16 fitting for the steering box and 2 90* elbows.
Attached Thumbnails LT1 Swap, Power Steering Hoses/Resovoir-ps-reservoir.jpg
Old May 8, 2004 | 07:03 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
update.
got ps pressure hose off 94-96 impalla lt1. worked fine.. a touch too long and perhaps could use a tweak, but hooked up fine, and i probably won't be tweaking it any.
resovoir, I think it will be epoxy'd on to the side of my overflow tank. perhaps a braket or something its hanging for now... no room where the above pics show it on pass side, and i wasn't too keen on the driver side. my battery is on the drivers side.. the ps hose, had a hole in it for what i assume is a bleeder. I didn't have such a beast and it didn't come with it nor did they have anything, so I used a 3/8 nc24 bolt cut down to size with a couple washers and loctite thread sealent.. no prob yet.. bleeding was easy.. lock to lock a few times till whine was gone.. no prob.. left top off resovoir tank when i did that checking of course to make sure tank was full and bleed air..
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
