305 to 350 conversion
Car: 92 silverado
I just put a 350 in my truck I know this does not reall aplly to you guys but it sounds like you know what your talking about and I keeping different story from everyone I talk to about this. I made the switch on saturday and I'm still using the 305 prom and injectors I did not switch the knock sensor or the ecs. I'm getting a pre ignition while I accelerate and the computer is running code 42. where do I go from here.
Greg
Greg
Car: 1990 Firebird
Engine: LS3
welcome to the boards
I'm not trying to be a smarta$$, but get the correct parts on there. I just did that swap and it works ok, all I have is the 350 knock sensor, and here is the key...a GOOD tune up. I put that in big letters because my car ran bad until I put new wires, plugs, cap, and rotor in, ohh and also a fuel filter. well good luck and hope this helps.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by red90bird
I suppose I should emphasize the part where I said it works "ok", not great and certinaly not perfectly, but it does get me down the road.
Car: 1990 Firebird
Engine: LS3
ya I know, its just a matter of fundage lately, and I'd actually like to get into burning my own chips as far as the prom goes. as for the right size injectors I'm holding out for being able to afford the holley 670 tbi.
plexman6000; I would bet that that those things would be good for you too
Car: '90 RS
Engine: 377 LSX
Car: 92 silverado
thanx for the help guys. Every thing is new wires cap rotor plugs and the fuel filter. Do you know what the part numbers are for a 350 ecs and 350 injectors? what could cause the computer to run code 42 would pre ignition set that off or could my distributor module and pick up be at fault.
Greg
Greg
Sanjay
Aug 12, 2015 03:41 PM
