305 HP Vortec 350
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
305 HP Vortec 350
Well, I'm not real sure if anyone cares, but I just had my car dynoed at the MidWest F-Body Meet,in Des Moines, Iowa,and came away VERY please with the results
The only thing I wish that could have been different, was to run it a little harder, to see where the cam would have started to nose over
But I told them to shut it down at 5500 rpm, to save the motor. Too bad, because the guys running the dyno said it was still making good power when they shut it down. Something about the motor not meeting the efficincy of the cam yet.
Anyway, heres the results, and these are RWHP numbers.
Max Power: 264.4 @5250 RPM
Max Torque: 273.8 @4500 RPM
Figure in the driveline loss, and it would be near 305 hp at the engine
P.S. I know that many others have stronger engines, but this engine started out as a $100 warrenty core, so I'm Happy
But I told them to shut it down at 5500 rpm, to save the motor. Too bad, because the guys running the dyno said it was still making good power when they shut it down. Something about the motor not meeting the efficincy of the cam yet.Anyway, heres the results, and these are RWHP numbers.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I bet your numbers would go up without the crappy stock air intakeon there. A $20 open element will go a long way on choked motor.
well, I'll tell ya', the idea of an open element air cleaner dosn't appeal to me, over my stock one.
for one thing, the stock one is ducted to the hood, so it can breath colder outside air. an open element air cleaner would only be breathing hotter underhood temps.
and as far as the intake goes, the performer already sits high enough to make the air cleaner rub the bottom side of the hood
I understand that there is always room for improvement for anything, but I also know what the intended purpose of my car is, to be enjoyable to drive and low maintanance. its not a race car, nor was it ever intended to be one, just a nice step up from the original LG-4 305, that it came with.
I'm not trying to compete with anyone, because no matter how fast your car is,(or how fast you THINK it is), there is always going to be someone with something faster.
and as far as future mods go, I think its time for some new seats and a headliner, for starters, and then there is always those TT2 wheels, I have been wanting
one more thing to add, as far as the numbers looking a little low, they were within 2-3 hp of the LT-1s that were there
Car: '90 RS
Engine: 377 LSX
on your face. Supreme Member
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
THe cam you have is the single pattern 235 dur @.050, .480 lift cam? That thing has got to be wanting more intake....
I bet you'd see another 15-20 rwhp easy with a RPM intake and drop-base open element filter setup... But anyway you're still making good numbers for a street car, especially if it was a Mustang Dyno, congrats.
I believe the LT-1s I looked at, were stock, and yes, it was a Mustang Dyno.
I would like to say one more time, that the run was cut short by me, before the horsepower peeked. I just didn't want it to come apart.
I asked them to stop at 5500 RPM, to be on the safe side.
I know now, that I could have safely run it up to 6500 RPM, and maybe found out were the TRUE max. HP was
Next year I'll definatly find out for sure
Thanks for all the comments guys
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
what the hell good does it do spinning a motor to 6500 rpm's if the powerpeak is 5250 like you say in your first post?
i can understand spinning it a little higher to get the rpm's up in the powerband for the next gear,but seems a litle senseless to spin it higher then needed...
btw,nice numbers,wish i would have went the route you went,ive spent assloads of money in my 383 and my cars been sitting since january,i envy you.
Like I'm trying to say, the run was cut short, at my request of 5500 rpm, but the print out that they gave me ended at 5250 rpm, with the horsepower still climbing.
I'm still a little confused as to why they didn't take it to 5500 rpm, but I guess that I have something more to look forward to next time.
To find the peak hp., going to 6500 rpm, might have shown were the cam would have run out of steam.
The guys running the dyno,also were confused as to why I wanted to limit the run to 5500rpm, because the HP was still increasing, at 5250 rpm. All I can say, is for myself, No Guts, No Glory, but I wasn't ready to take a chance at the engine being damaged, and being over a 100 miles away from home.
Car: 1984 Camaro 350 RV cam, Welded rear, 1987 Cutlass(330hpSBC), 1978 Chevy Truck, 1983 Mazda Rx7(getting SBC)
Engine: 350 RV cam
Transmission: T5(v6)
I have a vortec headed 355(not saying what it is in) but i got it dynoed in the middle of the winter with 215/70R15 winter tires!. I have a 200-4r so they had to start dynoing it at 3200 which was where the peak torque was so it could have even more but I will never know. They only dynoed it to 5100 rpm, for sum dumb reason, it should make peak HP at about 5800 RPM. The car was just dyned not ever tuned otr even the timimg played with, stock jetting in the carb. But heres the numbers.
Remember this is with a 200-4r so it is at 29% drivetrain loss.
236 hp at 4800 (dips down a bit at 500 but starts going up again at 5100)
328 Tq
that equals out to be 304 hp and 423 TQ, neither of these numbers are peak though, because the never took it to redline and because the started to dyno it after peak torque.
I want to get it dynoed again but this time I want to find a way to make the kickdown not work and take the motor right to 6500, that way i will know my peak hp and TQ numbers.
I think this engine is woth about 360hp and 435Tq.
328 Tq
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
